Help My 1989 Honda Civic Si 10amp soleniod problem
Old Jan 21, 2008 | 06:50 AM
turbhon's Avatar
Default Help My 1989 Honda Civic Si 10amp soleniod problem
Hello,
This all started about 4 months ago, under hard acceleration my 10amp fuse would blow, or if I changed gears when I would turn the car on. I ended up locating a loose/broken wire on the injector resistor box, so I relocated the box and soldered the wires back up. Anyway, last night after 4 months of no problem it sneaks up on me again and blew the same 10amp alternator/soleniod would blow again. At this point I am thinking, new injector resistor box, new main relay, new engine wiring harness, new alternator??
Anyone with any insight to this problem? It would be really helpful!
Thanks!~
Old Jan 21, 2008 | 09:06 AM
GSX 4G63T's Avatar
Do you have subs? I think your alternator can't handle the load of the accessories of subs,amps, you may need a capacitor so the fuse doesn't blow
Old Jan 21, 2008 | 09:20 AM
turbhon's Avatar
Default Re: (4163175587)
Hello,
I don't have an amp....
It seems to happen when going from the reverse gear to first sometimes....
94EGKUSH
14
Mar 16, 2009 05:10 PM
El3ments
Jun 2, 2008 11:55 AM
1fast90civicsi
Jul 8, 2007 12:35 PM
Bo0sted4Do0r
Apr 27, 2006 09:38 AM
stock4now
15
Sep 20, 2005 01:27 PM
