b20 sleeving
Old Jan 20, 2008 | 11:19 PM
illmatic520's Avatar
Default b20 sleeving
whats a good place to send out the block to get sleeved? any experience would be great.. thanks
Old Jan 21, 2008 | 07:27 AM
CerealKiller's Avatar
Default Re: b20 sleeving (illmatic520)
Golden Eagle Mfg. I believe they are the only ones that sleeve b20 blocks. Correct me if I'M wrong.
Modified by CerealKiller at 12:49 PM 1/21/2008
Old Jan 21, 2008 | 09:38 AM
jdmcx's Avatar
Default Re: b20 sleeving (CerealKiller)
i believe so i have not seen any one else doing it
Old Jan 21, 2008 | 02:10 PM
Golden Eagle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illmatic520 &raquo;</TD></TR><TR><TD CLASS="quote">whats a good place to send out the block to get sleeved? any experience would be great.. thanks</TD></TR></TABLE> we are one of the only ones sleeving them now pm me for pricing
Old Jan 21, 2008 | 02:39 PM
b18_spoon's Avatar
Default Re: b20 sleeving (Golden Eagle)
Why?
Old Jan 21, 2008 | 02:52 PM
Default Re: b20 sleeving (b18_spoon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18_spoon &raquo;</TD></TR><TR><TD CLASS="quote">Why?</TD></TR></TABLE>b20s are very different then b16 and 18s for sleeving because of the way their made and most sleeving shops will not guaranty them or even try to sleeve them but because we make all our sleeves in house we can sleeve almost anything and we have sleeved many b20s with no problems
Old Jan 21, 2008 | 03:27 PM
japan legend's Avatar
sounds good to me me..my friend has a turbo b20 on 10lbs and thats his daily hasent had any problems yet and he has been driving it for almost a year
Old Jan 22, 2008 | 05:19 PM
b18_spoon's Avatar
How different is the bottom of the B20 sleeve than the LS sleeve? I was led to believe that B20 blocks were basically bored LS's; therefore bad for boosting because the cylinder walls were thinner than LS. Visually I didn't see any of the typical webbing on the outside of the b20 block that the LS has either. Does that mean anything as well? I always figured the that as long as the sleeve was strong the rest of the block would hold up.
Old Jan 23, 2008 | 08:20 AM
the b20 is like a ls because it has the same stroke and uses the same rods but the casting is totally different the b20 sleeves are different then any other Honda but when it is sleeved it is fine and will hold up as good as any other Honda motor
Old Jan 23, 2008 | 09:14 AM
h22crxpwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Golden Eagle &raquo;</TD></TR><TR><TD CLASS="quote">the b20 is like a ls because it has the same stroke and uses the same rods but the casting is totally different the b20 sleeves are different then any other Honda but when it is sleeved it is fine and will hold up as good as any other Honda motor </TD></TR></TABLE>
GE got one of my blocks there now!
Old Jan 23, 2008 | 12:58 PM
ericksracing's Avatar
"RS Machines" also Sleeves B20 and they have always worked out for us
Old Jan 23, 2008 | 01:30 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: b20 sleeving (ericksracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ericksracing &raquo;</TD></TR><TR><TD CLASS="quote"> "RS Machines" also Sleeves B20 and they have always worked out for us </TD></TR></TABLE>
I was going to say RS machines does as well. I talked to them a few weeks ago about ordering a sleeved b20.
Kim Bay
11
Aug 17, 2009 07:47 AM
89 ef hatch
Oct 8, 2008 11:07 AM
Patron
Jul 1, 2005 07:42 PM
my_little_beast
20
Dec 25, 2004 11:02 PM
EVOLMTR
May 8, 2003 03:37 PM
