engine help
Old Jan 20, 2008 | 11:00 PM
michaelhinkle's Avatar
Default engine help
before i decide listening to problems i'll name whats been checked
dizzys fine, compressions fine, it's getting spark, foulded 1 set of plugs so it's getting gas, changed the timing belt and water pump, set timing (used a timing light so i know its set right)
It's a 90 civic wagon.
whenever i try turning the car over it sounds like its going to backfire (it doesnt)
I was thinking maybe it's a bad fuel injector but it'd still crank if only 1 was bad, right? and they can't all go bad at once! it broke down as i was going down the highway around 70mph, it acted as if it was running out of gas it just started putting out. when it goes to turn over it starts putting and it gives a weird sound from the exhaust.
any idea?
Old Jan 21, 2008 | 05:20 PM
Mikey3000's Avatar
Default Re: engine help (michaelhinkle)
sounds like cam timing is off. have u rechecked that?
Old Jan 30, 2008 | 08:31 AM
Default Re: engine help (Mikey3000)
sorry it took me so long to reply, ive been really busy with work. but no, i haven't. thanks.
anyone else? after i check/get that checked, i'll post.
Old Jan 30, 2008 | 08:36 AM
and might i add!
it will not turn over at all.
i took off the top to the fuel injection yesterday and tried pouring gas in it to see if it would crank and before i put the gas in i had a friend try turning it over and smoke shot out!
i almost **** myself. but fyi, pouring gas didnt work.
help mee.
Old Jan 30, 2008 | 09:56 AM
bump
Old Jan 30, 2008 | 09:47 PM
b-16eg's Avatar
if it dont turn over check starter or ignition. run a power to the starter to see if it turns and if it back fires, check your firing order. 1 3 4 2. cilinder 1 is closest to the crank pully.
Srt.ej1
Oct 22, 2015 10:23 PM
Loy
Dec 31, 2014 07:56 AM
:::SIRll_EJ1:::
Feb 6, 2010 12:55 PM
hebrewhammer8
18
Jun 2, 2009 07:46 PM
preludacris
Jun 25, 2004 09:29 PM
