~~~HELP~~~ OBD2a car... OBD1 engine... OBD2a ECU??????
Old Jan 20, 2008 | 10:42 PM
Spracer03's Avatar
Default ~~~HELP~~~ OBD2a car... OBD1 engine... OBD2a ECU??????
Ok so ive been searching around and ive found people using obd1 engines and harnesses in obd2 cars, all with ecu conversion harnesses. My question is can i use a complete obd1 engine(even dizzy, with no ckf senson on crank) in my 97 LS and run it off a obd2a ecu. will the ecu get its ckf signal from the dizzy or will i run into problems??
Old Jan 21, 2008 | 10:55 PM
lutherd300's Avatar
Default Re: ~~~HELP~~~ OBD2a car... OBD1 engine... OBD2a ECU?????? (Spracer03)
You want to use aOBD1 ecu , the p28 or p72 easy to chip and tune and the OBD1 ecu does not need the crank position sensor
Old Jan 22, 2008 | 08:16 AM
Spracer03's Avatar
i know the obd1 ecu would be best... but i need it to run for a while on a obd2a ecu so it can pass smog testing
frankiecutz
Engine Management and Tuning
Oct 4, 2010 01:15 PM
Ek9_Cuhzz
Northwest (Sales)
Jul 15, 2010 12:07 PM
Jap_Spec_Imports
Aug 10, 2009 07:11 PM
Spracer03
Jan 21, 2008 07:28 AM
dkrex001
Oct 25, 2006 02:09 PM
