Car wont accelerate Past 3,000 ???
Old Jan 20, 2008 | 07:06 PM
Brutale Turtale's Avatar
Default Car wont accelerate Past 3,000 ???
Ok heres the run down... i have a small-medium leak of oil from the crank seal... its gettng splashed around from the timing belt and w/e i have that problem so my friend took off my belt and tried to see where its leaking from and he put back the belt and now when the car is warmed up i cant accelerate till 3000 rpm. i put 30 weight oil in it and oil stop leak and no luck
it seriously boggs down and i have to hold the clutch in and accelerate and let it go at 3k rpm.
im wondering if i need to put more oil in it bc i havent checked it or a sensor or w.e please help me figure out whats wrong.
heres a pic for refrences
Old Jan 20, 2008 | 07:09 PM
GSX 4G63T's Avatar
Check your vacuum lines. Then check your purge solenoid on the firewall. They look like little black canister. Check the top for cracks.
Old Jan 20, 2008 | 07:13 PM
so just check for cracks??
and the vaccum lines to the selenoid?
im going to check it right now
Old Jan 20, 2008 | 07:16 PM
Crx Jimmy's Avatar
Default Re: (4163175587)
if you had the timing belt off and its leaking from the crank, why didnt you replace the crank seal?
Old Jan 20, 2008 | 07:18 PM
jdm_titan's Avatar
Default Re: Car wont accelerate Past 3,000 ??? (Brutale Turtale)
the car is in limp mde was it dpfi turned into mpfi??
Old Jan 20, 2008 | 07:19 PM
GSX 4G63T's Avatar
Default Re: (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">if you had the timing belt off and its leaking from the crank, why didnt you replace the crank seal?</TD></TR></TABLE>
When he removed the t belt it stopped leaking. Didn't he say it leaked before by the crank. He must be confused where the crank is? lol
ok i checked the selonoid and no cracks that i can see and the lines look good.. this is an si. no dpfi to mpfi
Old Jan 20, 2008 | 07:20 PM
GSX 4G63T's Avatar
SI= Sport Injection and its PG-MPFI by looking at your intake
Old Jan 20, 2008 | 07:21 PM
he didnt replace it bc i dont have the money to by a new one... i know sad
Old Jan 20, 2008 | 07:22 PM
GSX 4G63T's Avatar
Default Re: (Brutale Turtale)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brutale Turtale &raquo;</TD></TR><TR><TD CLASS="quote">he didnt replace it bc i dont have the money to by a new one... i know sad </TD></TR></TABLE>
It's only 8.99 at napa
Old Jan 20, 2008 | 07:23 PM
i know i dont have the money LOL
is there any way to bypass my cars (limp mode)?
Old Jan 20, 2008 | 07:42 PM
GSX 4G63T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brutale Turtale &raquo;</TD></TR><TR><TD CLASS="quote">i know i dont have the money LOL
is there any way to bypass my cars (limp mode)?</TD></TR></TABLE>
Come on, ask your parents for some money. This seal is crucial....That may be it. I think I know why its acting up. There is no oil pressure and your oil pump is working OT to build up the necessary pressure at specific RPM. Get the seal!!!
Old Jan 20, 2008 | 11:43 PM
nihad's Avatar
I beleave that your dizzy is causing this
Old Jan 21, 2008 | 04:51 AM
1net's Avatar
Default Re: (nihad)
and i believe that someone didn't put the timing belt in the correct position
limp mode is identified with a rev-limiter at 3000 and a constant CEL. and as far as I can see he has not mentioned any of these.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">SI= Sport Injection and its PG-MPFI by looking at your intake</TD></TR></TABLE>
A well done MPFI swap cannot be told apart from a real D16a6 so i think the question was more than adequate.
Old Jan 21, 2008 | 07:01 AM
jdmrex90si's Avatar
it could be the plug wires couse my buddys car had the same problem an it was the plug wires that coused it
577HondaPrelude
Jun 22, 2009 10:15 AM
00MugenLude
May 16, 2007 08:31 AM
Don
Sep 1, 2004 01:44 PM
pro547
May 15, 2004 09:14 PM
