First time changing oil problem
Old 05-15-2004, 08:47 PM
pro547's Avatar
Default First time changing oil problem
ok today my father and I decided to change the oil for the first time in my new civic. so everything goes nice and stuff we get the new filter in and everything run for 10 minutes then let it sit for 10 minutes then check the oil level and everything is ok. So right before I go to work today i start her up and it is taking longer to start. Why is this? My belts are really squeaky and it was changed at 92,139 miles also water pump antifreeze. Anyone know why my belts are squeaky? After I drive for awhile the squeaky goes away.
Thx
Silas
Old 05-15-2004, 08:51 PM
ibe2fly's Avatar
Default Re: First time changing oil problem (pro547)
did any oil spill ? dunno why it would take longer to start up ... but squeakiness might be caused but some oil spillage perhaps on the belts... just taking a stab in the dark ... check belts for wear though ... don't wany any of those bad boys breaking
Old 05-15-2004, 08:59 PM
ej1 pilot's Avatar
yeah definitely check the belts, spray them with some brake cleaner while its runnong, spray it all including the pulleys
Old 05-15-2004, 09:06 PM
pro547's Avatar
Default Re: First time changing oil problem (Sl0wEH2)
yea thx i will check the belts tomorrow before i got to work.
Old 05-15-2004, 09:10 PM
h22John's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sl0wEH2 &raquo;</TD></TR><TR><TD CLASS="quote">yeah definitely check the belts, spray them with some brake cleaner while its runnong, spray it all including the pulleys</TD></TR></TABLE> DO NOT SPRAY YOUR BELTS with anything but air!!!!! geez what are you saying?? Don't lend bad information. It may not cost him much if the accesory belt goes but what about a timing belt?
Old 05-15-2004, 09:14 PM
RangerDan's Avatar
Default Re: First time changing oil problem (h22John)
Were you low on fuel? Low fuel will cuase less fuel pressure...thus harder starts.
Side Note..Hey John.
lilpaintballer02
01-04-2010 01:19 PM
4drDC2
21
01-21-2007 09:27 AM
kevin85193
06-12-2005 11:42 AM
Tench
07-10-2004 10:34 PM
95 GaNgStA AcCoRd
11-03-2002 07:47 PM
Quick Reply: First time changing oil problem
