will the d15b2 non vtec wiring hardness fit a d16z6 vtec
this question has been probably asked before but i cant find it so
will the d15b2 non vtec wiring hardness fit a d16z6 vtec also i've heard that i will require a dpfi to a mpfi conversion is this true
just like any other honda harness you can use it for that but it will have to be re pinned for what you need depending on if you sensors are all from the same OBD, is it MPFI or DPFI etc etc etc if your good with wiring know how or where to find pin outs for your ecu/harness you can do it
But if your not so inclined go to rywire or get the harness from the model car your motor came from + mpfi swap if needed
hopefully that helps but try to search better next time
hey i did my swap too but i get bashed on for it. just search for dpfi>mpfi swap and it'll run. i got my car running cool with obd0
but yeah, thats just my opinion. goodluck with your swap! triple check everything before you start your car
Also, if you are at least somewhat electrically inclined, it is not too hard to modify the harness yourself to run the motor. It may take some time and effort. But with the money you save, you can go out and buy yourself a header.
ur d15 engine harness needs to be convertied to multi port. or rywire... but after completed it will work on any d b series motor with a few parts swapped plus vtec wiring and ecu
puertoricanboy90
14
Aug 7, 2008 10:09 AM
