Question for k-pro
I HAVE AN DC5.COLD AIR INTAKE.HEADER,RBC MANIFOLD AND THE REFLASH LOOKING ON GETTING K-PRO-WHEN I SEND MY ECU.IS IT BACK TO STOCK WHEN I GET IT.THEN I HAVE TO TUNE IT.OR IS THEIR BASE MAPS.CAUSE THERE ARENT REALLY ANYBODY IN SAN ANTONIO TO TUNE K-PRO.
yoo man i got question look
I have an 03' RSX Type-S and just recently i got the engine washed ( yea dum move by my part) and now i am having problems with the Map Sensor that is reading at 8.0 % when it should be higher and the TPS is reading at 32.5% very high. I want to know if it might be that my whole ECU is going bad or that these sensors are just needing to be changed. Help Plz. thanks.
and my rpms idle kind low
yes, kpro comes with several base pre-tuned maps that you should be able to work with just fine until you can take it somewhere. And for the thread jacker, what did you wash it with? you can wash engine bays without damaging anything as long as your not pressurewashing up close or youve got a hose right over some sensors
as boostownsne said, there are some base maps you can choose from thats closes to your setting
go to clubrsx.com and sent 'justin_c' a pm about looking for a tuner in san an
i'll sure he'll find you someone in the area
threadjacking flt
i've washed my engine a few times and its fine
when i'm done, i use a leaf blower to get all the excess water out
idk, never had a problem when i did it
threadjacking flt
