fuel pump not priming
Old Jan 20, 2008 | 05:42 PM
crx_si-r's Avatar
Default fuel pump not priming
ok here is the story. a couple days ago my clutch pedal broke one me. so this morning my buddy brought one over to me and i installed it and my heater as well. so i took out the dashboard to make things a bit easier on me. i went to put everything back together and and noticed that the new pedal assembly didnt have a clutch switch, so i figured not prob ill just jump it. put the new heater in and new pedal assembly in. now i put the dash back in and was just about finished, went to start the car and it did for a few seconds then died. i turned the key to the on position and i dont hear the fuel pump prime. so i switched main relays and still nothing. ive given up for the day as there is no more sunlight and will give it another go in the morning. any suggestions as to what may have happened? thanks guys
Old Jan 20, 2008 | 06:27 PM
IP RACING's Avatar
Default Re: fuel pump not priming (crx_si-r)
if it started and died and its not your relay. it could be a few things. did you connect all the grounds/ have you gone over all grounds period.? checked your fuses?. same thing happened to my car and I just fixed it today. it was my ignition lock. try starting your car and right before you let go of the key keep it in between the 2nd postion and start. that way your getting power but your starter isnt running. if it keeps running its either your igniton switch or your ignition lock
Old Jan 20, 2008 | 07:12 PM
crx_si-r's Avatar
Default Re: fuel pump not priming (IP RACING)
yea thats wat i was thinkin that i might have left one of the grounds off. ill re-check in the mornin.
Old Jan 20, 2008 | 10:58 PM
crx_si-r's Avatar
where are the dash board grounds and how many are there?
Old Jan 21, 2008 | 08:21 AM
thevtecnician's Avatar
There is a ground by the hood pop latch and one under the cluster above the steering column
rx_86
Apr 1, 2010 04:49 PM
civic08
Mar 14, 2010 09:26 AM
garyhgaryh
Aug 8, 2007 05:26 PM
B20_ej1
16
Apr 2, 2007 04:14 PM
ragethemachine86
Sep 21, 2006 11:08 AM
