Suspension & Brakes Theory, alignment, spring rates....
are these any good?
Old Jan 20, 2008 | 04:06 PM
4MyEyesOnly's Avatar
Default YONAKA (Ever heard of these coilover)?
Does anyone have these or know about them. want to know if there good?
96-00 HONDA CIVIC EK YONAKA TRUE COILOVERS
SKU:
Featuring: All Aluminum Upper Mounts 0-4" Height adjustment. Fully Threaded Mono Tube Shock Absorber. Inner bump stop to prevent damage cause by rapid compression impacts. Wide range of height adjustment without changing the spring compression. Bottom of the shock is threaded to allow height adjustments without having to shorten the suspension travel. Rubber dust shield protecting piston for long life. Adjustment tools included. Spring rates are as follows: Front springs: 12kg / 180mm Rear springs: 6kg / 200mm
PRICE: $550.00
http://www.outlawzzracing.net/...etail
Modified by 4MyEyesOnly at 6:50 PM 1/21/2008
Modified by 4MyEyesOnly at 9:28 PM 1/21/2008
Modified by 4MyEyesOnly at 5:32 PM 1/22/2008
Old Jan 22, 2008 | 01:33 PM
Default Re: YONAKA (Ever heard of these coilover)?
BUMP
Old Jan 22, 2008 | 02:15 PM
TunerN00b's Avatar
Default Re: YONAKA (Ever heard of these coilover)? (4MyEyesOnly)
12k/6k spring rates? Sounds like a cheap solution for a "slammed" street car. Also sounds rather uncomfortable for daily use (nearly 700lbs/in front rate).
Old Jan 24, 2008 | 04:18 AM
mlrmotorsports's Avatar
Looks like junk to me
Old Jan 24, 2008 | 04:27 AM
toyomatt84's Avatar
Sanji
Expect the dampers to blow out, the collars to "self-weld" to the adjustment rings, and to only see about 1 - 2 weeks of actual ride comfort.
Chinese manufacturer.
Old Jan 24, 2008 | 05:25 AM
unusual71's Avatar
you get what you pay for.
people who like their setups and haven't had problems with them over a year or more usually had spent 1000$ plus.
So if you want to spend half that good luck getting half the performance and half the life span.
Old Jan 24, 2008 | 08:17 AM
Default thank you
thanks for the help, my boys friend has a shop and sells these. didnt know or even heard of em so thats why i wanted to know about them.
itrdave
Feb 9, 2022 10:16 AM
mperezkr
Aug 15, 2007 05:49 AM
2DoorBandit
Suspension & Brakes
Jan 25, 2006 01:50 AM
91SiKen
Mar 5, 2002 06:34 PM
