crank but no start
Old Jan 20, 2008 | 03:25 PM
killacam20's Avatar
Default crank but no start
so during a heavy storm, i drove through a deeper than i thought puddle and sucked up a good amount of water. (Boo CAI) Car died and didnt want to try to start too much. Got it towed home
I removed spark plugs and sucked out a bunch of water with a tube and syringe. Then cranked without wires/plugs getting more water out. Changed oil with the intention of running it and then changing again, but it wont start. It will crank now but wont start. I dont think there is much water left in there. What could it be?
Im thinking it could be rusted spark plugs but what else should i check?
any suggestions or tips would be great
Old Jan 20, 2008 | 03:43 PM
jhammond_82's Avatar
Reject Papi
Default Re: crank but no start (killacam20)
are you getting spark?
Old Jan 20, 2008 | 04:40 PM
killacam20's Avatar
Default Re: crank but no start (jhammond_82)
no spark on all 4
Old Jan 20, 2008 | 04:42 PM
Blahblah718293's Avatar
spark plugs shouldnt rust that quick. if theyre wet though they can arc without firing the cylinder.
Old Jan 20, 2008 | 04:45 PM
db1_jdm's Avatar
Forget it, most likely you hydro-locked ur motor.
Old Jan 20, 2008 | 05:08 PM
killacam20's Avatar
Default Re: crank but no start (db1_jdm)
if its cranking i dont think its hydrolocked. should i try new spark plugs?
Old Jan 20, 2008 | 05:32 PM
weavertime1's Avatar
Check your distributor (cap, rotor, etc), and yes maybe you might want to install new plugs and wires, or borrow a friends just to see...if you have friends.
Old Jan 20, 2008 | 05:40 PM
red integra lsr's Avatar
Check all fuses and relay. You might have shorted out some thin
Old Jan 20, 2008 | 10:57 PM
Greasemonkey75's Avatar
Is your ignition rotor in the distrubitor spinning with the motor??
Old Jan 21, 2008 | 04:43 PM
MrViet's Avatar
HYDRO- LOCKED ! remove the intake and then check ur intake manifold, 5$ says ther's water still in there u should get all the water out. also, try to manually crank your car to make sure your rods are fine. if you try to manually crank it and it doesn't move.....GG
teamTakeo
Aug 20, 2023 07:58 PM
sames1
Honda CR-V & Element
13
Oct 4, 2015 06:04 PM
streetsweaper
13
Oct 3, 2005 05:36 PM
wanna b R
Aug 25, 2004 01:02 PM
eky2k
Feb 3, 2004 02:10 PM
