stock R exhasut.
beaten to death * 100000000 times,
the smallest part of the exhaust comes down to about 2.25 inch. (...approximately)
nope... here is what i've gathered on this topic... if i'm wrong someone please correct me.
JDM Exhaust system:
JDM 4-1 header with 2.5" collect
JDM ITR Cat with 2.5" Inlet...but the outlet is the same size as the USDM b-pipe
(the JDM cat is shorter... so the JDM bpipe is longer to accomodate for it.. I believe it's essentially the same as a USDM GSR bpipe??)
JDM ITR Muffler is the same as the USDM
JDM Exhaust system:
The biggest part is 2.25 inch (57 mm) OD. The smallest is about 51 mm OD. And some bottlenecks are 54 mm OD.
Actually the worst bottle neck is at the B pipe flange is 1.9" OD (48mm) with an ID of 1.75" (44.5mm).
