Timing camshafts to TDC
Old Jan 20, 2008 | 01:20 PM
apeek's Avatar
Default Timing camshafts to TDC
I'm having a hell of a time timing my h23 after a timing belt/headgasket replacement. What is annoying my is the tick marks on the cam gears, so i got some questions.
Are the exhaust and intake cam <U>Gears</U> different or the same?and also just to triple check how can i tell the diff. between exhaust and intake cams to be 100% i didnt dick up putting them back in.
I know to put the cams at tdc is to have the UP arrows up and the tick marks on the gears on the inside and even with eachother.
The tick marks are supposed to the parrellel with the head correct? Its a pain in the *** to see if they actually are with the fender in the way.
Is there an easier way to see that they are in the correct position?
Thanks for the help!
Old Jan 20, 2008 | 01:31 PM
Hawkze_2.3's Avatar
Default Re: Timing camshafts to TDC (apeek)
You want the up arrows to be pointing up and the lines on the sides to be pointing right at eachother...they will be relatively parallel to the head, but if you try to get it exact you will just give yourself a headache. Anyhow, the arrows need to be up and matching while the TDC mark on the flywheel (white plus sign) is lined up with the marker on the engine block.
You are using the flywheel to do timing right?
Old Jan 20, 2008 | 01:49 PM
apeek's Avatar
Default Re: Timing camshafts to TDC (Hawkze_2.3)
the PLUS mark.......?
Well I'll go do that.., shoot I've been puttin it on the white - mark, the plus mark is also white, what the hell, lol.
Thanks!
Old Jan 20, 2008 | 01:56 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by apeek &raquo;</TD></TR><TR><TD CLASS="quote">the PLUS mark.......?
Thanks!</TD></TR></TABLE>
Sounds like you're at the same place I was one time, haha. I could NOT get it running right until I took a break and saw that I wasn't using the plus sign.
Old Nov 10, 2008 | 11:41 PM
Tarlacon's Avatar
SERIOUSLY!??!?! a plus mark? SH*T, i have been using the - mark... AHHHHHHH
Old Nov 11, 2008 | 07:03 AM
Acidcrakker's Avatar
Default Re: Timing camshafts to TDC (Tarlacon)
What about the crank gear. there are TDC marks on them too.
I line the crank gear up first and check the TDC marks on the fly wheel as a back up.
Not all Hondas have the TDC marks on the flywheels. I did a SOHC accord the other day and there was no service hole for the flywheel on it.
Old Nov 11, 2008 | 06:18 PM
snobordboy's Avatar
Moderator
Yeah, you need to be either setting the crank off of the crank gear and the mark on the oil pump, or finding #1 tdc through the plug hole. I would only trust the crank gear method personally, since you should have that stuff all apart anyways!
Old Nov 11, 2008 | 06:27 PM
vinuneuro's Avatar
Default Re: (snobordboi)
Like others have said, do it off the timing gear and oil pump. There's no other way it'll be accurate.
Old Nov 12, 2008 | 03:29 PM
Mikey3000's Avatar
stick a punch through the service hole in the cam cap bridges and into the hole in the camshafts. stop [freak]ing with those stupids cam gear marks. as far as knowing which cam is which, the exhaust cam has the notch on the end for the distributor.
Aqueous5
Mar 5, 2008 09:15 AM
ZXRider
Dec 19, 2006 02:43 PM
bluedlude
Nov 9, 2006 06:31 AM
gATOr65
Dec 27, 2005 02:03 PM
impr323
Oct 9, 2005 05:33 PM
