LCA? Camber kit required?
Old Jan 20, 2008 | 12:12 PM
spotscivic's Avatar
Default LCA? Camber kit required?
so i have some tire rubing issues in the rear of my 97 ex and i want to get rear LCA arms. and my ? is do you need to have a camber kit for when i put the new rear arms on?
Old Jan 20, 2008 | 12:19 PM
B16b-EJ8's Avatar
Default Re: LCA? Camber kit required? (spotscivic)
Nope...no need for a camber kit with new LCA's, but an alignement will be a good idea at wich point the shop will tell you you need camber kits to get your alignment perfect and then charge you an arm and a let for them but you really dont need them....However i'm not sure how LCA's are going to fix your rubbing issues. What size wheel are you runnning and how low is your drop?
z6hatchboy's Avatar
You dont need them but, if your slammed its a very worth-while investment and you might as well take care of it while your under there.
Old Jan 20, 2008 | 01:10 PM
spotscivic's Avatar
Default Re: LCA? Camber kit required? (B16b-EJ8)
im at stock, no drop. my wheels/tires are 7" wide.
Old Jan 20, 2008 | 01:13 PM
Powered by VTEC's Avatar
what are your tire size?
Old Jan 20, 2008 | 02:13 PM
spAdam's Avatar
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spotscivic &raquo;</TD></TR><TR><TD CLASS="quote">im at stock, no drop. my wheels/tires are 7" wide.</TD></TR></TABLE>
Whoa... and youre rubbing? Youmust have some ginormous tires or really low offset to be rubbing like that...
Old Jan 21, 2008 | 03:03 AM
B16b-EJ8's Avatar
Default Re: LCA? Camber kit required? (spAdam)
Even still if your expecting to rid your rubbing problem LCA's are not going to do it.
Old Jan 21, 2008 | 06:07 AM
spotscivic's Avatar
looks like plan b.. roll the fenders
Old Jan 21, 2008 | 06:12 AM
electron_si's Avatar
the only rubbing issues the LCA's will fix is if your stock lca is rubbing against the inside of your wheel.
LCA's dont change suspension geometry, they are just a direct replacement part
Old Jan 21, 2008 | 06:17 PM
spAdam's Avatar
Loved
Community Favorite
Default Re: LCA? Camber kit required? (electron_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by electron_si &raquo;</TD></TR><TR><TD CLASS="quote">
LCA's dont change suspension geometry, they are just a direct replacement part</TD></TR></TABLE>
Except SPC's... they are shorter than stock, correcting the camber at the bottom.
HFP-EP3
12
Nov 17, 2007 01:09 AM
dixie Normas7
Sep 8, 2006 11:17 AM
EKhybrid
Suspension & Brakes
Jun 17, 2005 10:33 PM
MSP
Jan 13, 2005 02:13 AM
