Those of you with SI crx and aftermarket LCA's
Old Jan 20, 2008 | 11:58 AM
SIred91's Avatar
Rainman
Default Those of you with SI crx and aftermarket LCA's
Does the stock SI swaybar bolt back up to Blox LCA's?
Or do you have to buy the end link kits as well?
Old Jan 20, 2008 | 12:17 PM
Crx Jimmy's Avatar
Default Re: Those of you with SI crx and aftermarket LCA's (SIred91)
It should work fine, if they are like the omni you might need a couple washers to space the end link out a bit and possible a longer bolt/locknut. Nothing a trip to the harware store cant fix, IF you do need new bolts make sure they are grade 10.9 if metric and grade 8 if you use standard thread.
Old Jan 20, 2008 | 01:01 PM
SIred91's Avatar
Rainman
Default Re: Those of you with SI crx and aftermarket LCA's (Crx Jimmy)
Locknut? what are you talking about? The oem just bolts directly to the lca.
Spacers?
Please explain what you are talking about.
Old Jan 20, 2008 | 03:58 PM
SIred91's Avatar
Rainman
Anyone? How do you use your stock sway with aftermarket LCA's?
Old Jan 20, 2008 | 05:14 PM
Crx Jimmy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">Locknut? what are you talking about? The oem just bolts directly to the lca.
Spacers?
Please explain what you are talking about.</TD></TR></TABLE>
Most of the aftermarket ones are aluminum and just have a hole with no threads inside, so you either use a 10mm or 3/8 bolt with some washers and locknut on the other side, its self explanitory if you have them in your hand
Old Jan 20, 2008 | 05:22 PM
MaverickEF9's Avatar
I have just put EG LCA's in my EF, discovered that the OEM EG LCA had just a hole for the swaybar mount whereas the EF LCA has a nut brazed inside for the swaybar bolt to thread into. Just used some 10mm bolts with locknuts and washers as described above and it works fine
Old Jan 20, 2008 | 07:04 PM
SIred91's Avatar
Rainman
Default Re: Those of you with SI crx and aftermarket LCA's (MaverickEF9)
Cool. Thanks guys.
category5 SI
29
Mar 27, 2016 02:28 PM
HotCheetos
10
Dec 11, 2010 09:07 PM
civicdelsol33
Suspension & Brakes
Dec 19, 2007 10:26 PM
_Cyclone_
10
May 16, 2005 01:15 PM
yellowcrx88
Jul 9, 2003 04:56 PM
