BLINKERS DON'T WORK! HELP!!!!
Old Jan 20, 2008 | 11:56 AM
ksu5's Avatar
Default BLINKERS DON'T WORK! HELP!!!!
So, I have a 1996 honda accord and the blinkers for some reason or another have stopped working. I started the car for the day and they didn't work when the night before they were fine. I checked the fuse, fine, checked to make sure the hazard button was not half way pushed in, fine. The hazards work and regular lights work fine so i know its not a bulb. This has happened before and I did something very simple and they started working again but can't quite recall what it was that I did. Any suggestions or idea of what might the problem?
Old Jan 20, 2008 | 07:42 PM
oem_certified_accord's Avatar
Default Re: BLINKERS DON'T WORK! HELP!!!! (ksu5)
did you check the turning signal fuse or the small light fuse?
Old Jan 20, 2008 | 08:12 PM
ksu5's Avatar
Default Re: BLINKERS DON'T WORK! HELP!!!! (oem_certified_accord)
both. but its not the bulb i believe because don't the hazards use the same bulb as the blinker ?
Old Jan 20, 2008 | 08:21 PM
-shrugs- i would go to the garage and tell you but my lady's locked up away for transport. sorry bro
Old Jan 21, 2008 | 10:04 AM
02 accord's Avatar
Check your blinker fluid.
peter.s
Apr 9, 2018 05:27 PM
revvhavok
Aug 30, 2009 08:19 AM
chatman_55
Jul 21, 2009 09:53 AM
Swansen
Apr 20, 2009 05:44 AM
Bewkrazed
Apr 2, 2004 03:05 PM
