Code 19
Old Jan 20, 2008 | 11:16 AM
pkdog167's Avatar
Default Code 19
Just want to know if low transmission oil will make the ecu throw code 19 (Automatic transmission lockup control valve) or not? Also will it effect gas milage??
Old Jan 20, 2008 | 02:47 PM
ifIexplode's Avatar
The Lock-up Control Solenoid Valve, is more commonly known as the Torque Converter Clutch (TCC) Solenoid. , controls the lock-up function of the torque converter.
its lookin like its a solenoid problem. Idk much about auto transmissions, hope that helps
When is the last time you replaced the Fluid and filter
Old Jan 20, 2008 | 03:22 PM
pkdog167's Avatar
Default Re: (ifIexplode)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ifIexplode &raquo;</TD></TR><TR><TD CLASS="quote">The Lock-up Control Solenoid Valve, is more commonly known as the Torque Converter Clutch (TCC) Solenoid. , controls the lock-up function of the torque converter.
When is the last time you replaced the Fluid and filter </TD></TR></TABLE>
Well I never change the filter since I own it and the fluid was replace about 700miles ago when I did the swap.
Lawrence Nguyen
Sep 14, 2021 12:12 PM
charlierem
Apr 19, 2017 11:06 PM
allvtecyo
10
Aug 2, 2014 11:07 PM
h22_crx
Dec 8, 2007 08:56 PM
peja43916
Dec 30, 2004 11:43 PM
