when its WOT the motor shuts down?? HELP!!!
Old Jan 20, 2008 | 11:14 AM
DEL HATCH's Avatar
Default when its WOT the motor shuts down?? HELP!!!
i searched last night for some info, found similar topics, but alot of them didnt have the solution once it was fixed..
at 1/2 or 3/4 throttle, the motor is fine. drives fine, hits vtec, no problems
motor is a 95 gsr-completely stock
once its at WOT, no matter what RPM it shuts down- doesnt shut off, doesnt gain/lose power, totally shuts down and does nothing..
i changed my head gasket and put a new throttle body on, and since then its been doing this..
***********IM NOT THROWING ANY CEL'S**********
this is what ive done so far to try and correct it:
changed spark plugs
changed spark plug wires
changed dizzy rotor
checked timing 4 different times
ive checked my vacuum lines, dont see anything wrong or not hooked up
please help.. anything you can think of
Old Jan 20, 2008 | 03:27 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: when its WOT the motor shuts down?? HELP!!! (DEL HATCH)
pop off the tps, and make sure the lug on the tps is engaged.
then go back with a meter and make sure the closed and wo.ot. spec voltages are right. id give em to you but i am not 100% sure on the specs. i want to say somewhere around half a volt closed and 4.8ish to 5 w.o.t.
Old Jan 20, 2008 | 03:31 PM
DEL HATCH's Avatar
Default Re: when its WOT the motor shuts down?? HELP!!! (boostedcivicsir)
cant i just check the voltages and make sure its ok so i dont have to take it off?
Old Jan 28, 2008 | 04:42 PM
DEL HATCH's Avatar
it was the TPS sensor.. i just never figured it could be since it didnt throw a code.. the green and yellow wires were switched around-switched them back and now everything is fine.. thanks for all the help guys!!
BLinindoll
16
Feb 26, 2013 11:29 AM
DEL HATCH
Jan 28, 2008 04:59 PM
DEL HATCH
Jan 28, 2008 04:41 PM
ZCcivicBOI
May 4, 2006 01:32 PM
scrEaMO Kyle
Jan 25, 2005 07:55 AM
