when its WOT the motor shuts down??? HELP!!
Old Jan 20, 2008 | 11:12 AM
DEL HATCH's Avatar
Default when its WOT the motor shuts down??? HELP!!
i searched last night for some info, found similar topics, but alot of them didnt have the solution once it was fixed..
at 1/2 or 3/4 throttle, the motor is fine. drives fine, hits vtec, no problems
motor is a 95 gsr-completely stock
once its at WOT, no matter what RPM it shuts down- doesnt shut off, doesnt gain/lose power, totally shuts down and does nothing..
i changed my head gasket and put a new throttle body on, and since then its been doing this..
***********IM NOT THROWING ANY CEL'S**********
this is what ive done so far to try and correct it:
changed spark plugs
changed spark plug wires
changed dizzy rotor
checked timing 4 different times
ive checked my vacuum lines, dont see anything wrong or not hooked up
please help.. anything you can think of
Old Jan 20, 2008 | 06:01 PM
DAneronimo's Avatar
Default Re: when its WOT the motor shuts down??? HELP!! (DEL HATCH)
tps?
Old Jan 20, 2008 | 06:43 PM
DEL HATCH's Avatar
Default Re: when its WOT the motor shuts down??? HELP!! (DAneronimo)
wouldnt that make it run like crap all the time? or at least throw a code?
Old Jan 21, 2008 | 03:37 AM
polishedturd's Avatar
I like PIE
fuel pump is going out
Old Jan 21, 2008 | 09:40 AM
LastGenEK's Avatar
Default Re: when its WOT the motor shuts down??? HELP!! (polishedturd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by polishedturd &raquo;</TD></TR><TR><TD CLASS="quote">fuel pump is going out</TD></TR></TABLE>
That would be my guess
Old Jan 22, 2008 | 03:40 PM
DEL HATCH's Avatar
Default Re: when its WOT the motor shuts down??? HELP!! (LastGenEK)
fuel pump has been replaced when i bought the car like 7 months ago..
Old Jan 22, 2008 | 04:58 PM
GhostAccord's Avatar
My first pick would be TPS given the circumstances tha tyou are describing.
Do you have access to a volt meter so that you can check/adjust the TPS. At least that way you can rule out the tps at no cost.
With the ignition on car not running the closed throttle voltage should be approx 0.5v and the voltage should move up gradually to WOT @ approx 4.5v. Get yourself a haynes manual if you don't already have one. This proceedure is in the book. I don't have the time right now to write up what wires to check or the exact proceedure.
Get the TPS out of the way and then go from there.
Old Jan 22, 2008 | 05:54 PM
sorrule's Avatar
first try swapping your tps and map sensor plugs. It won't throw a code if they are mixed. then check tps with volt meter then swap you fpr if the first thing doesn't work.
Old Jan 28, 2008 | 03:49 PM
Brick Top's Avatar
get that tps done yet?
Old Jan 28, 2008 | 04:40 PM
DEL HATCH's Avatar
Default Re: when its WOT the motor shuts down??? HELP!! (Brick Top)
it was the TPS sensor.. i just never figured it could be since it didnt throw a code.. the green and yellow wires were switched around-switched them back and now everything is fine.. thanks for all the help guys!!
Old Jan 28, 2008 | 04:59 PM
Brick Top's Avatar
good to hear
myessay
Dec 14, 2010 04:33 PM
DEL HATCH
Jan 28, 2008 04:42 PM
DEL HATCH
Jan 28, 2008 04:41 PM
WannabeEF9
Aug 29, 2005 02:37 PM
scrEaMO Kyle
Jan 25, 2005 07:55 AM
