GSXR 750 injectors and ITBs
Hi guys,
google didn't help a lot, so i decided to try here...
I'm preparing a set of GSXR 750 (i believe its 2001) ITBs and it seems I will have to use the injectors that
came with them. My quiestion is if someone knows what those injectors' flow rate is.
Thanks in advance
Thanks in advance
The flow rate is 240cc and they are a low impedance injector. You will need a resistor box to run them. I had to do the same research for my setup, I'm going to use them as a secondary set of injectors.
b16bri
Sep 5, 2010 02:53 PM
Schister66
Apr 26, 2006 08:36 AM
