GSR NOT REVING OVER 7rpm. Why
Old Jan 20, 2008 | 08:45 AM
typerslpr's Avatar
Default GSR NOT REVING OVER 7rpm. Why
Old Jan 20, 2008 | 09:05 AM
jhammond_82's Avatar
Reject Papi
Default Re: GSR NOT REVING OVER 7rpm. Why (typerslpr)
push the gas pedal further.
Old Jan 20, 2008 | 09:18 AM
jdmjunkie8's Avatar
you need alot more details
Old Jan 20, 2008 | 09:24 AM
Rickdrizzle's Avatar
oh snaps.
Old Jan 20, 2008 | 08:14 PM
typerslpr's Avatar
Car runs normal It just started one morning after i put the stock ecu back.from runing a chip one. May dirty oil cause it?
97 Ek
JdM Da$H 10K
B18c1
skunk2 mani
skunk2 70mm tb
421 header
2.5exhaust no cat no resinator
msd ing
full fuel system Pump etc............
Old Jan 20, 2008 | 11:31 PM
DC4R27's Avatar
you might want to check your air filter. one time i was driving on the freeway and was pushing it, but my car topped out at 110mph, i dont know exactly what rpm that was, but it wouldnt go any more than that, even though i was full throttling it. later, i checked my intake, and my filter was super duper clogged. after i cleaned it, my car was back to normal and it ran fine.
Old Jan 21, 2008 | 02:35 AM
33_Red_Gsr_33's Avatar
is it like a limiter feeling, like it jerks forward kinda at seven or a top speed governer feeling?
Old Jan 21, 2008 | 12:13 PM
typerslpr's Avatar
Default Re: GSR NOT REVING OVER 7rpm. Why (33_Red_Gsr_33)
Just like a rev limiter at 7000! and goes no more doesn't matter what gear.
Old Jan 21, 2008 | 12:19 PM
steveo135's Avatar
is there a check engine light?
Old Jan 21, 2008 | 01:19 PM
IntegraType-R's Avatar
Default Re: GSR NOT REVING OVER 7rpm. Why (steveo135)
lmfao, did u put in a ls ecu?
Old Jan 21, 2008 | 01:43 PM
da9stalker's Avatar
Default Re: GSR NOT REVING OVER 7rpm. Why (IntegraType-R)
Were you at operating temp?? Oil level full??
Old Jan 21, 2008 | 01:49 PM
tomithy's Avatar
What "stock ecu" did you put back in?
Old Jan 21, 2008 | 06:02 PM
typerslpr's Avatar
Default Re: (tomithy)
Everything work find when I change the ecu 2 the chip one. today But the syock one just started 2 do out out the blue. My check engine light is always on when stock gsr 0bd2a. NO 2nd o2. chip p28 is working fine know . Thank everyone
what will make the ecu 2 do that it may just need a reset. maybe let me know
90 g2 4dr -Totaled
90 g2 b18C1- Daily driver
97 EK b18C1- COME GET SOME
Old Jan 21, 2008 | 06:05 PM
Micha's Avatar
FAILWGN
Default Re: (typerslpr)
You have a huge throttle body for a basically stock NA motor.
And you're stock ignition system would do just fine on your setup.
Old Jan 21, 2008 | 06:17 PM
typerslpr's Avatar
Default Re: (micha)
tubro this spring. Use juice
civic402lx
Mar 12, 2017 07:15 AM
RegCRVtec
Mar 1, 2009 11:58 AM
Tegraracer90
Feb 1, 2009 02:35 PM
sinanalo
Honda Civic (2001 - 2005)
18
Feb 5, 2007 08:35 AM
pearlteg
Jul 18, 2004 10:05 PM
