Fuse box question...need help, I'm in the dark
Old Jan 20, 2008 | 05:32 AM
kilroy79's Avatar
Default Fuse box question...need help, I'm in the dark
ok this may have been asked before but while changing bulbs on one of my interior lights , ( that is, the lights in the headliner, by the rearview mirror, and between the front seats) I somehow managed to pop a fuse or something because now neither of them are working .
so I popped open the fuse box panel and find that there is no listing on it for interior lights that I can see. have checked the obvious dash lights work, turn signal works , horn , wipers , headlights, backup lights, radio , heater , everything works exept the two interior lights , it is a 2000 EX by the way . no SRS light or any other lights comming on on the dash.
any Ideas?
Old Jan 20, 2008 | 07:35 AM
aeboync's Avatar
Default Re: Fuse box question...need help, I'm in the dark (kilroy79)
Im confusied, you didnt mention if you actually checked to see if you blew a fuse... I mean you said you opened the fuse box and didnt see a fuse listing.. anyway, hope this helps...
Old Jan 20, 2008 | 09:50 AM
kilroy79's Avatar
all the fuses under the dash were good, I was trying to find out witch fuse controls the dome lights???
Old Jan 20, 2008 | 10:15 AM
ifIexplode's Avatar
There is a Fuse in the Under the Hood box.
Its for Ceiling light/trunk light/
its a 7.5a Fuse.
#43
https://honda-tech.com/zerothread?id=2200320
All that info up above is good, Ive never seen that online before. Bookmarked
edit: i got all that info out of the servive manual i have. the one the dealers use.
Modified by ifIexplode at 11:40 AM 1/20/2008
Old Jan 20, 2008 | 06:27 PM
NOFX's Avatar
H-T White Ops
The fuse diagrams (along with full explanations) are here:
https://honda-tech.com/zerothread?id=1966666
I'll be setting up some diagrams for the under hood ones soon.
Old Jan 21, 2008 | 05:19 AM
kilroy79's Avatar
Default Re: (NOFX)
thanks alot guys, helped out a lot . changed the fuse under the hood and have light again, no longer in the dark! lol
cor4ey
Apr 16, 2010 03:53 AM
Luke G.
10
Sep 27, 2009 08:32 AM
JDM H22
Dec 13, 2007 01:59 PM
dra600n
Apr 7, 2004 11:21 AM
