questions about bulbs, educate me
ok i have a em2 that takes 9003 style headlight bulb, those are the ones with the double filments correct. So my question is that will a H4 bulb work if i just plug it in the socket? Im sure those are for the HID, arent they. I know they burn hotter than 9003, im guessing they have less resistance which makes have alot more amperage to the bulb, which will probaly blow my fuse, i know you cant put a high number fuse because the wire wont handle higher amps. so do you have to buy the whole pnp kit, are can you buy just the bulbs?
