dx caliper removal
Old Jan 19, 2008 | 05:24 PM
black0hatch's Avatar
Default dx caliper removal
how do i take the caliper off there the one 12mm bolt then i can pivot it up to change the pads. do i just slide the whole thing out? usually theres 2 12mm bolts and the caliper will come off but on this car theres only 1.
Old Jan 19, 2008 | 05:45 PM
ILcrxsi1's Avatar
I tell doctors what to do
Default Re: dx caliper removal (black0hatch)
Yeah just pull the caliper off of that slide.
Old Jan 19, 2008 | 07:15 PM
Donkey85's Avatar
Default Re: dx caliper removal (ILcrxsi1)
thats correct, then the bracket is held on by two 17MM bolts. remove that and there you go
Old Jan 19, 2008 | 07:25 PM
spikehead221's Avatar
From: Staring down the barrell of my 12 ga. Texas, USA
make sure that you only do one side at a time
just in case
besides that, it was super easy to change the pads on my dx
Old Jan 19, 2008 | 07:32 PM
GSX 4G63T's Avatar
Remove the bottom caliper bolt. Loosen the top bolt alittle and the whole caliper will swing up and out of the way(i use a piece of mechanic wire and hook it to the spring to keep it out of the way)Now you can remove the pads and install new. Force the caliper piston flush with the caliper frame using a large c-clamp. Remember to remove brake reservior cap to not let air in when pushing the piston in. Now the new pads will slide over the rotor. oh yeah now is a good time to bleed the system.
Old Jan 20, 2008 | 08:30 AM
Default Re: (4163175587)
no i need to take the cailper off the bracket the caliper needs to be rebuilt. theres only one 12mm bolt and it slides off like the first guy said.
civlxbro
Suspension & Brakes
Sep 24, 2009 02:25 PM
b20vdelsol619
Aug 4, 2009 07:10 PM
The_Todd
Sep 6, 2004 08:55 AM
deviant1
Dec 21, 2002 04:21 AM
leechungsr
Aug 25, 2001 03:39 PM
