igniton lock cylinder how to put in
Ive searched non stop all day. and I cant find out how to put the new one in!. taking it out was fairly simple but the install of the new one isnt going well. how do you put in the new lock cylinder.
did you take off the break away bolts? if you did then to put it back on was easy I always use the same bolts you use to bolt down the front seats
should be a screw or torx screw on the side of the lock. you also have to take the metal collar off the top of the lock, which guards the keyway. and should be some kind of pin you push in. it's been a while
Bishop1976
Sep 29, 2012 08:48 AM
sohcjdm
Feb 24, 2010 04:38 PM
