new 2 NHRA please help?
Old Jan 19, 2008 | 11:52 AM
projectef's Avatar
Default new 2 NHRA please help?
to run in the NHRA meets to i have to join or just show up at the NHRA meets? i been in BOTI and stuff, is it the same? planin to go on this 08 season.
Old Jan 19, 2008 | 11:59 AM
projectef's Avatar
never been to a NHRA sport compact meet before
Old Jan 19, 2008 | 12:01 PM
4piston's Avatar
Default Re: (projectef)
You can just show up at the Nopi/NHRA events and register there, or you can do it in advance.
Old Jan 19, 2008 | 12:03 PM
projectef's Avatar
advance like on the NHRA sportcompact web?
Old Jan 19, 2008 | 12:42 PM
SPOOLINmatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectef &raquo;</TD></TR><TR><TD CLASS="quote">advance like on the NHRA sportcompact web?</TD></TR></TABLE>
no, when everything is situated like it should have been already, youll be able to get your membership on the Nopi Drag Racing website and sign up for all the other stuff. You will be able to do it at the races to but it helps to do it online or on the horn when they get it all ready.
Old Jan 19, 2008 | 01:11 PM
projectef's Avatar
my bad bout the to many ?'s but, is it jus nopi.com and go under register or what?
Old Jan 19, 2008 | 02:08 PM
ExospeedAMcrx's Avatar
Default Re: new 2 NHRA please help? (projectef)
Look at the top of this Drag Racing forum at the racing schedule. It will show all the races across the nation and their locations. See what you are able to go to and check with those sanctioning bodies what the requirements are on the class you want to run in. No need to preregister or anything like that. Just show up that day and make sure you have the proper safety requirements.
Old Jan 19, 2008 | 02:37 PM
fast is fun's Avatar
Default Re: (4piston)
http://www.nhrasportcompact.com
Old Jan 19, 2008 | 07:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectef &raquo;</TD></TR><TR><TD CLASS="quote">my bad bout the to many ?'s but, is it jus nopi.com and go under register or what?</TD></TR></TABLE>
you cant register yet so........
Old Jan 19, 2008 | 08:09 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: (SPOOLINmatt)
If you want to run NOPI you will need to register with NHRA because it is NOPI sanctioned by NHRA. Go here to get a registration: http://store.nhra.com/product.asp?0=203&1=211&3=25
If you plan on earning points you will need a NHRA competition number. There are two types of member competition number. If your car runs slower than 9.99 and less than 135mph you need to fill this out:
http://www.nhra.com/contacts/forms/nolicense.pdf
If your car run faster than a 9.99 or 135mph or greater then you need to get a license and a physical. Here are the forms you need for that:
http://www.nhra.com/contacts/forms/licenseapp.pdf
http://www.nhra.com/contacts/forms/physical01.pdf
art
Old Jan 19, 2008 | 08:12 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: (Arturbo)
And dont wait to get your license if you run faster than a 9.99 or 135mph or faster. Get this done asap!! If you dont have your license you will be kicked off the track or DQ'd.
art
Old Jan 22, 2008 | 02:39 PM
projectef's Avatar
thanks 4 da help
Jerseyfan
Nov 24, 2007 09:15 AM
old guy
Jan 27, 2006 07:27 PM
ExospeedAMcrx
Jan 22, 2005 08:03 PM
enrique
Jun 26, 2003 05:32 AM
