battery drain narrowed down to taking ecu fuse out what could be causing this
Old Jan 19, 2008 | 10:33 AM
blackccoupe's Avatar
Default battery drain narrowed down to taking ecu fuse out what could be causing this
ok i was getting a battery drain so i narrowed it down to a drain where my ecu fuse if i take the fuse out it stops if it is in it keeps running what ever it runs. does anyone know if there is a relay or something that would cause this any help is appreciated
Old Jan 19, 2008 | 11:39 AM
stocker2shocker91's Avatar
I requested a short story for a title.
Default Re: battery drain narrowed down to taking ecu fuse out what could be causing this (blackccoupe)
wel since pretty much everything runs through the ecu its kinda hard to have it narrowed down. what all have you checked?
any aftermarket gauges or sterio?
Old Jan 19, 2008 | 12:01 PM
lmike6453's Avatar
one mistake i made in teggy when i first got her is hooking up the amp n head unit to a harness with the wiring clipped...when i turned off the car the amp stayed powered on and killed battery in a week
Old Jan 19, 2008 | 12:03 PM
Default Re: (lmike6453)
no system , when my buddy had the car before me he had soome vac line hooked up wrong to his blow off valve and it blew the fuse some how from then on if the fuse was in it would turn the main fuel relay and a couple other sensors on under the hood on if it is out they dont run i replaced all the sensors with no luck
Old Jan 19, 2008 | 12:22 PM
Default Re: (blackccoupe)
hmmm i have never heard that one before?
the best bet might be time consuming, but unplug something each night and see if it is dead in the morning and right down what you unplugged.
no the dumb questions
1)have you had the batt tested
2)how are the connections?
Old Jan 19, 2008 | 12:42 PM
Default Re: (stocker2shocker91)
yes battery is good and connections are good like i said it has to do with what is in line with the ecu fuse
bluestd
Sep 12, 2009 05:02 PM
95_red_dc
Jul 23, 2007 09:01 PM
zoom545
Mar 5, 2006 12:54 PM
Pearlude
Nov 14, 2004 06:41 PM
Loudnissan
Aug 9, 2003 12:19 PM
