need help!!!accord running weird
Old Jan 19, 2008 | 10:28 AM
T9U4ReBgO's Avatar
Default need help!!!accord running weird
I just bought a 93 accord with a f22a6 I believe...well car runs great but sometimes if u are just crusing and u start accelerating the car has no power at all and won't go anywhere...If I cut the car off then start it back up its fine...no CEL or anything...plugs,wires,vacuum lines,coil are brand new...I'm thinking map sensor but idk any ideas???? Thanks
Old Jan 19, 2008 | 10:48 AM
NeKe1point0's Avatar
Default Re: need help!!!accord running weird (T9U4ReBgO)
nddng a better description of what <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T9U4ReBgO &raquo;</TD></TR><TR><TD CLASS="quote">car runs great but sometimes if u are just crusing and u start accelerating the car has no power at all and won't go anywhere...If I cut the car off then start it back up its fine...</TD></TR></TABLE>
a more descriptive post could help diagnose your problem easier...
Old Jan 19, 2008 | 11:41 AM
T9U4ReBgO's Avatar
Default Re: need help!!!accord running weird (NeKe1point0)
um well like I said u can just be crusing at one speed and as soon as u try to speed up its like it isn't getting any fuel...first thought was fuel filter but it doesn't to it all the time??? Any question u have and I can answer for more info?
Old Jan 19, 2008 | 12:00 PM
T9U4ReBgO's Avatar
ok it just threw a check engine light...can u check those the same way u do in a civic...under the pass kick panel and stick a paper clip in the DLC and let it blink the code???
Old Jan 19, 2008 | 12:13 PM
well that was almost as vague as the first one but heres what id suggest...
did it come with any maitnce book of past repairs ? look over all recpts of prev work if so...
since <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T9U4ReBgO &raquo;</TD></TR><TR><TD CLASS="quote">plugs,wires,vacuum lines,coil are brand new...</TD></TR></TABLE>
i would obviously start with the basics and go from there
here are some poss probs it could be jst off the top of my head :
throttle cable
air filter
fuel filter
fuel pump
injectors
does it do it at a certain rpm or speed ? have u tried to rev it up in park past when it would normally act up ?
Old Jan 19, 2008 | 12:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T9U4ReBgO &raquo;</TD></TR><TR><TD CLASS="quote">ok it just threw a check engine light...can u check those the same way u do in a civic...under the pass kick panel and stick a paper clip in the DLC and let it blink the code???</TD></TR></TABLE>.
yes, pull the code and scratch that last post
Old Jan 19, 2008 | 12:26 PM
T9U4ReBgO's Avatar
so it is in the same area as the civic and check it the same way correct..
Old Jan 19, 2008 | 12:28 PM
paper clip ftw !!!
Old Jan 19, 2008 | 12:34 PM
T9U4ReBgO's Avatar
Code 43
Old Jan 19, 2008 | 01:50 PM
T9U4ReBgO's Avatar
bump
Old Jan 19, 2008 | 04:09 PM
3zFree's Avatar
Code 43 is Fuel supply system or your oxygen sensor circuit
Old Jan 19, 2008 | 05:38 PM
loup05's Avatar
Default Re: need help!!!accord running weird (3zFree)
code 43? hmm i think thats the o2 sensor code isnt it? if it is thats the sae code i threw when my o2 went out... but my car would missfire real bad.. like i would go WOT and it would go nowhere it would feel like it was under a big load and it would missfire like crazy
418whpturboD
May 20, 2008 08:46 AM
Project_SOHC_EX
Aug 25, 2004 12:09 PM
