Water leaking??
I have a 92 accord. I drove it a lot yesterday and when I pulled it in the driveway I noticed a huge puddle of antifreeze. It had just started leaking but when I went to figure it out the next morning it had stopped. I poured more antifreeze in the reservor and the radiater but still no leak any where. I know there was something wrong with it last night but not this morning. I can't figure it out and I'm not all that good with cars. I don't know if it only leaks when it gets hot because I did run it a lot that day. If somebody could please give me a suggestion I would appreciate it. Thanks
Do you see any puddles of antifreeze or wet spots in the engine compartment anywhere? Look on the engine and tranny or maybe the cross member that holds the rad. Where was the puddle located in relation to the engine, drivers side, passenger side, front, back or in the middle?
Best way to find a leak in your cooling system is to have it pressure tested.
Other wise idle your car up to temp (build coolant pressure) and see if you can find the leak that way.
NullPointer
11
Sep 10, 2020 08:59 AM
juevi
14
Aug 21, 2011 01:34 PM
PINKS
30
Aug 23, 2006 08:13 PM
