Any performance if i just swap a ITR inake came n ITR intake valve?
Old Jan 18, 2008 | 11:30 PM
Powered by VTEC's Avatar
Default Any performance if i just swap a ITR inake came n ITR intake valve?
Any performance gain if i just swap a new oem ITR intake cam and new ITR intake valves cause exhaust cam is almost the same as b16a. and running with stock pistons set up.
its for my jdm sir2 engine.thanks
Old Jan 19, 2008 | 04:44 AM
Default Re: Any performance if i just swap a ITR inake came n ITR intake valve? (Powered by VTEC)
no one knows?
Old Jan 19, 2008 | 06:49 AM
ProMotive's Avatar
Minimal at best, you'll need to get tuned to really take advantage of them.
Old Jan 19, 2008 | 04:15 PM
Default Re: Any performance if i just swap a ITR inake came n ITR intake valve? (ProMotiveConcepts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProMotiveConcepts &raquo;</TD></TR><TR><TD CLASS="quote">Minimal at best, you'll need to get tuned to really take advantage of them.</TD></TR></TABLE>
i still need to get it tuned even i dont change the compression ratio ?
Old Jan 19, 2008 | 04:23 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Powered by VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
i still need to get it tuned even i dont change the compression ratio ?</TD></TR></TABLE>
If you change your cams you need to get it tuned to take full advantage of it.
Think of it logically, what's the use of adding more air (larger lift duration) if you're not also adding more fuel?
I'll math it out for ya:
X air = Y fuel
You put a cam on:
X + 5 air still = Y fuel.
You get it tuned so X + 5 air = Y + 5 fuel.
- hope that helps some.
Old Jan 19, 2008 | 04:45 PM
Default Re: Any performance if i just swap a ITR inake came n ITR intake valve? (Syndacate)
understand.got it now. thanks.
Old Jan 19, 2008 | 09:10 PM
highroller54's Avatar
type r valves are not a strait bolt in for a b16 head.
Old Jan 19, 2008 | 09:26 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: Any performance if i just swap a ITR inake came n ITR intake valve? (highroller54)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highroller54 &raquo;</TD></TR><TR><TD CLASS="quote">type r valves are not a strait bolt in for a b16 head.</TD></TR></TABLE>
Why not? It's the same head.
Old Jan 19, 2008 | 09:28 PM
doood's Avatar
been there done that
orly? please, elaborate.
Old Jan 23, 2008 | 04:58 PM
Default Re: Any performance if i just swap a ITR inake came n ITR intake valve? (doood)
yes head is the same but the valves are 1mm oversized
Old Jan 23, 2008 | 06:07 PM
Hardedge's Avatar
I'm pretty sure they are not. I heard of lots of people straight swapping for Type R valves because they're lighter. By the way, valves don't "bolt" in.
Old Jan 23, 2008 | 06:56 PM
Default Re: (Hardedge)
haha^^ I definitly could be wrong
Old Jan 23, 2008 | 07:07 PM
RMXmitch's Avatar
they are the same size...
just the shaft is cut on the itr's to make them lighter, some will argue that this makes them weaker...
Old Jan 23, 2008 | 08:27 PM
doood's Avatar
Default Re: (RMXmitch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highroller54 &raquo;</TD></TR><TR><TD CLASS="quote">yes head is the same but the valves are 1mm oversized </TD></TR></TABLE>
yea umm....they're not
HaTa
Nov 10, 2006 02:49 PM
TsukubaSpec
Sep 14, 2005 09:49 PM
92integraVTECgsr
Jun 12, 2005 07:58 PM
xfrankx
May 18, 2005 05:30 AM
jfoster
Jan 1, 2004 04:33 PM
