rear lca question
Old Jan 18, 2008 | 11:05 PM
frontwheelfanatic's Avatar
Default rear lca question
will 94-01 integra rear lower control arms work on a '88 civic hatch? reason for changing is to run the the 89+ civic style shock, and i got an extra set of dc lca's laying around
Old Jan 18, 2008 | 11:13 PM
GSR CRX's Avatar
Default Re: rear lca question (frontwheelfanatic)
i heard the dc is slighly longer which will give you a bit of negative camber. but, then again skunk2 sells their lca's with the same part number. i know that doesnt really answer your question much but it might help if you have a rear camber kit that way it can be an easy fix.
Old Jan 18, 2008 | 11:15 PM
Default Re: rear lca question (GSR CRX)
i'm guessing they're a bit longer just like the da ones are when you install them on an 88-91. thank you, i got my answer they're going on in the morning
Old Jan 19, 2008 | 08:50 AM
Crx Jimmy's Avatar
they are the exact same length, same as a eg as well. when you get them hold them up and you wil see all the holes line up the same
solfire
11
Nov 9, 2013 07:56 AM
ribal_gh
Suspension & Brakes
Mar 15, 2013 01:21 AM
wasabivtec
Jul 20, 2011 09:47 AM
FaNiO
Oct 11, 2009 06:36 PM
Teglessb18
Jul 26, 2008 09:14 AM
