EK Hatch GSR swap
I just swap in a GSR in my 97 Hatchback CX, and i was wondering what throttle cable do i need to use? I tried the stock one and its way too loose. I have a Stock GSR one but under the dash where it connects to the pedal is different. I was thinking about cutting the stock one and get one of those wire stops and put in there. Let me know what cable people are using.
I use the stock one for a while. I just got two longer bolts and some washers for spacers. Looked tacky but worked till I got a gsr cable. The gsr cable one will go on its just a bitch.
Cool Cool Island Breezes. BOY-EE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 994door »</TD></TR><TR><TD CLASS="quote">I use the stock one for a while. I just got two longer bolts and some washers for spacers. Looked tacky but worked till I got a gsr cable. The gsr cable one will go on its just a bitch. </TD></TR></TABLE>
The slightly more expensive solution would be to get an aftermarket manifold with a B16A or ITR throttle body and bracket and cable.
Hmm, I had to do the washer thing even with the GSR cable
Either way, the GSR cable works (with possible modification)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious »</TD></TR><TR><TD CLASS="quote">
The slightly more expensive solution would be to get an aftermarket manifold with a B16A or ITR throttle body and bracket and cable. </TD></TR></TABLE>
Theres only one thing about that, Yes i do have an aftermarket and it would make things a lot easier, but i am going to State Ref the motor in the car and we all know how strict California BS is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alacard »</TD></TR><TR><TD CLASS="quote">
Hmm, I had to do the washer thing even with the GSR cable Either way, the GSR cable works (with possible modification)</TD></TR></TABLE>
I have a GSR cable out of a 95 GSR but the place on the pedal accepts a different type of cable holder and is way different. the one on my car looks like a big thick washer as to the ones that we normally see.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed_1 »</TD></TR><TR><TD CLASS="quote">
I have a GSR cable out of a 95 GSR but the place on the pedal accepts a different type of cable holder and is way different. the one on my car looks like a big thick washer as to the ones that we normally see.</TD></TR></TABLE>
Hmm, well I don't remember any issues with mine (01 gsr in 99 civic)...Maybe the 95 throttle cables were different from the newer models? Have you tried putting it in despite the differences...maybe it just looks like it won't fit, but it actually will.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmtcrxsir »</TD></TR><TR><TD CLASS="quote">i dont think that will affect your outcome with the ref. </TD></TR></TABLE>
A Skunk2 Intake manifold would make a world of difference when it come to State reffing a car. the goal is to make it look stock as possible as if the motor came in that car from the factory, its the visual part that Kills.
Hmm, well I don't remember any issues with mine (01 gsr in 99 civic)...Maybe the 95 throttle cables were different from the newer models? Have you tried putting it in despite the differences...maybe it just looks like it won't fit, but it actually will.</TD></TR></TABLE>
I tried it and no luck i will look into the newer GSR.
import-tooner
Jan 25, 2011 05:30 AM
eggsi619
Jun 29, 2009 11:14 AM
EVIL Hx Coupe
Mar 20, 2005 06:52 AM
Phatch99
10
Jun 18, 2004 12:56 PM
