350Z as a tow vehicle?
Okay, I know it isn't ideal, but the new 350Z is supposed to make 267lb/ft of torque. Think that is enough to pull a sub 1900lb CRX on a two wheel tow dolly? If I get the highest model of the Z, it comes with Brembos, so braking should be sufficient. The problem is clutch/transmission related, and the fact that the car is very low to attach a hitch to. Any thoughts?
Matt
Matt
should be fine, hell my pathfinder only has 197 lb-ft, is 2 wheel 5 speed, w/ 115,000 miles and pulls fine, the old Z are supposed to have a bullet proof tranny so the new ones should be good, by the way i just replaced the clutch in my path 2,000 miles ago, the clutch was fine but the throwout bearing was shot.
do it matt, that would be a cool tow vehicle and would have more than enough power
Matt
350Z has 274ft-lbs torque, 287hp.
I don't know how good of a tow vehicle it would be since the tranny isn't designed to withstand heavy loads, and the driveshaft is carbon-fiber. But who knows, it may serve as an adequate tow vehicle, but I know my 350Z won't...
I assume (and hope and pray) that you said this in jest.
But, I wouldn't do it. Unibody cars don't take so well to towing stuff. They tend to stretch, twist, and generally fall to bits. That is why my Caprice (body on frame sedan) is rated to tow more than a 6L Cherokee (unibody truck).
If you want a fast tow vehicle, consider a '96 Impala SS or possibly a '03 Mercury Marauder.
I'm curious as to how well the suspension on the 350Z would take to the weight of the CRX pressing down on the back end. Trans temp could be an issue as well.
The Marauder is body-on-frame and has a large displacement, torquey motor. I'd bet it's rated at 2000lbs, but could tow more with helper springs or air bags. My Caprice (similar size as the Merc) is rated at 2000lbs stock, or 6000lbs with a load-leveler and helper springs.
reliabilty shouldn't be too much of an issue...the problem is the gutless automatic tranny that won't let the car rev to redline.
wants a Crown Vic w/Mustang engine for a beater
[Modified by Ross, 1:35 AM 7/2/2002]
wants a Crown Vic w/Mustang engine for a beater[Modified by Ross, 1:35 AM 7/2/2002]
But I wouldn't enjoy driving a Maruader every day. I'm looking for a fun daily driver that I can use to tow...
Matt
Matt
All crown vics have mustang motors...
How about the new Range Rover? Would that be a nice tow rig?
Keep in mind that when I talk about fun to drive, straight line speed means a lot less to me than handling. If I could only find a way to use a 350Z.....
Matt
Joel
how about a 2 wheel drive 5 speed pathfinder w/ the 3.5 motor, (ie. same as my truck but w/ 70 more hp)
thikn about it, my truck weighs 3680 lbs empty, 240 hp in that weight ain't bad, and ask joe and eric, that thing was pretty fast around cmp e/ 5 guys in it
seriously, get the lightning, that's what slow ser has and he autox it, has had it out on the VIR full course and tows w/it,, perfect combo
or, how about a used BMW 528 wagon w/ a 5 speed, don't hawve to worry about auto tranny temps and they make a hitch for it because the tow w/ it in europe
I dunno about the Nissan. I'm in dreamland here, but if I needed and could afford a medium-duty tow vehicle I'd have to go with the V8 Tundra. I just can't get used to Domestic ergonomics. Of course the big diesel Domestics are the only way to go for heavy-duty towing.
The new supercharged Frontiers and XTerras kick total ***.
Or, how about a 255hp '03 Maxima?
Jon
who is employed by Nissan and then spends all his paychecks on his Nissan
Jon
dohdoh420
Aug 29, 2006 02:38 PM
12thstreetjunkman
20
Mar 3, 2004 07:00 PM
