m22 vs m24x ?
Old Jan 18, 2008 | 05:45 PM
RISRdotNet's Avatar
Default m22 vs m24x ?
I hear that they recommend m22's with ~11:1 and m24x with ~12.5:1
do you think you'll lose power with m24x's on 11:1 compared to m22s?
Thanks!
Old Jan 18, 2008 | 05:58 PM
sikcivic95's Avatar
Default Re: m22 vs m24x ? (RISRdotNet)
my old poor mans type r setup (rip) was way overcammed with m24s.. the compression was about 11/5/1 and it didnt make near the power the m22xs did.. i called rocket and they said i could send back the m24s and gave me m22xs! great customer service on rockets part! but id go with m22x with that setup.. when they say use it with "such and such" compression then you better go with what they say.. hope that helps! good luck man!
Old Jan 18, 2008 | 06:03 PM
Chris Tune's Avatar
cam selection is more on engine size, desired rpm etc etc than actual compression... but following guidelines is sometimes good when you dont know much
Old Jan 18, 2008 | 07:04 PM
Aquafina's Avatar
M22 for a 1.8L. Could get away with M24 if your engine can support high RPM and you have gearing to match it.
Old Jan 18, 2008 | 11:03 PM
Dyno Dave's Avatar
Capacity/setup is the key as others have posted already for the correct cam selection.
Regards Dyno Dave
Old Jan 19, 2008 | 06:06 PM
blacK_Dc4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RISRdotNet &raquo;</TD></TR><TR><TD CLASS="quote">I hear that they recommend m22's with ~11:1 and m24x with ~12.5:1
Thanks!</TD></TR></TABLE>
besides compression , what displacement is your engine ? .. i ve tried both the m22x and the m24x on the same 2.0L motor but its not a good comparison if ur question is regarding a 1.8 L
Old Jan 21, 2008 | 12:21 PM
RISRdotNet's Avatar
Default Re: m22 vs m24x ? (blacK_Dc4)
1.8 ls/vtec w/ p30 pistons, looking at a b16 style head w/ a gsr quench style combustion chamber, thanks guys
Old Jan 21, 2008 | 01:08 PM
blacK_Dc4's Avatar
yea with that kind of setup , m22x will be good .. might want to look in to the m22xx as well
Old Jan 21, 2008 | 06:48 PM
Aquafina's Avatar
Just use a GSR head. It'll work better than the B16. If RI has 93 set your CR a little under 12:1. M22X will work well. If you have quality parts (and selection) and a good tuner, M22XX would be nice. XX is for a hot setup moreso than a mild street setup.
Old Jan 22, 2008 | 09:50 AM
Rocket's Avatar
Default Re: m22 vs m24x ? (Aquafina)
M22x.
Most friendly of the "hot" cams from RM but still has alot of "*****."
Cam choice is based on "port loading". When people make there engines bigger like going from 1.8 to 2.0 they increase the port loading because the ports/intake manifold runners are seldom made larger. This increase in port loading and allows you to run more duration.
This is why it is absurd to make a general statement such as 2.2 liter B motors has to have Pro 3's and Mustang 5.0 should have Pro 8's.
Old Jan 22, 2008 | 12:02 PM
Dyno Dave's Avatar
Default Re: m22 vs m24x ? (Master of the Universe)
Most people overcam there smaller cc engines or dont get there cyl heads ported enough to support the cams and then complain the cam/profile is crap and xxxx brand is better and all it means is they dont understand how to design the correct combination of parts to make the power they want.
Regards Dyno Dave
Old Jan 22, 2008 | 04:20 PM
UncleD's Avatar
Default Re: m22 vs m24x ? (Dyno Dave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dyno Dave &raquo;</TD></TR><TR><TD CLASS="quote"> they dont understand how to design the correct combination of parts to make the power they want.
Regards Dyno Dave </TD></TR></TABLE>
Sig worthy.
fitseries3
K Series
Feb 28, 2015 06:35 PM
madking411
31
Feb 4, 2011 05:45 AM
Death_to_Thieves
Apr 24, 2004 08:46 PM
birz
Jan 26, 2004 12:12 PM
