3rd gear b16 tranny grind...
Old Jan 18, 2008 | 01:31 PM
mesonerz's Avatar
Default 3rd gear b16 tranny grind...
ok well ive been looking for a b16 tranny for my 94 gsr...i found one today for really cheap but it has the 3rd gear grind....i did do search on this topic but i still have one qusetion..is there anything else i should be aware of that goes along with the 3rd gear grind or is that just the basic problem??
Old Jan 18, 2008 | 01:43 PM
redDAinteg's Avatar
Default Re: 3rd gear b16 tranny grind... (mesonerz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mesonerz &raquo;</TD></TR><TR><TD CLASS="quote">ok well ive been looking for a b16 tranny for my 94 gsr...i found one today for really cheap but it has the 3rd gear grind....i did do search on this topic but i still have one qusetion..is there anything else i should be aware of that goes along with the 3rd gear grind or is that just the basic problem??</TD></TR></TABLE>
its a basic problem if you know how to rebuild the tranny. It has a grind more than likely due to mis-shifting or powershifting the gears. Either the gear itself has some rounded teeth that cause the grind or some teeth have been broken straight off or IMO the synchro is bad and needs to be replaced. The Trans will only get worst until it has the needed parts replaced.
If you are fine with the grind than go for it. Good Luck.
Old Jan 18, 2008 | 02:10 PM
mesonerz's Avatar
Default Re: 3rd gear b16 tranny grind... (redDAinteg)
cool thanks for the reply
Old Jan 18, 2008 | 04:37 PM
JThrasher79's Avatar
i wouldent buy any transmission that has a grind.
they only get worse..
Old Jan 19, 2008 | 06:16 AM
vtec95's Avatar
Default Re: 3rd gear b16 tranny grind... (JThrasher79)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JThrasher79 &raquo;</TD></TR><TR><TD CLASS="quote">i wouldent buy any transmission that has a grind.
they only get worse..</TD></TR></TABLE>
X2!
Old Jan 19, 2008 | 11:27 AM
TOUGE4LIFE's Avatar
NO LEGS
Default Re: 3rd gear b16 tranny grind... (vtec95)
3rd gear grind is no fun , how cheap is the tranny?
LoneAutosport
Transmission & Drivetrain
Mar 15, 2010 04:39 PM
MrExclusive
Feb 4, 2010 07:52 AM
creepy116
Dec 11, 2006 12:21 PM
BMo Tuning
Sep 13, 2005 11:25 AM
Bense
16
Oct 29, 2004 06:25 AM
