*+*DO YOU KNOW A RIMS SHOP THAT DOES THIS WORK*+*
Old Jan 18, 2008 | 12:45 PM
JiZzEr's Avatar
Default *+*DO YOU KNOW A RIMS SHOP THAT DOES THIS WORK*+*
i think its called titanium chroming..please let me know if you know a shop that can do this for me im located in so cal near torrance thanks
**OH AND IF YOU DONT KNOW A SHOP YOU CAN HELP BY <U>BUMPING </U> this up
Old Jan 18, 2008 | 01:17 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: *+*DO YOU KNOW A RIMS SHOP THAT DOES THIS WORK*+* (JiZzEr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JiZzEr &raquo;</TD></TR><TR><TD CLASS="quote">**OH AND IF YOU DONT KNOW A SHOP YOU CAN HELP BY <U>BUMPING </U> this up</TD></TR></TABLE>
The "one bump" limit on this forum applies to bumps by anyone, not just the original poster. The second bump gets the topic locked.
Old Jan 18, 2008 | 02:16 PM
TunerN00b's Avatar
A light coating of oil, on a chrome wheel, will produce the same effect.
However, I have never seen a shop paint or coat a wheel to produce that effect. Looks neat though.
Old Jan 18, 2008 | 02:27 PM
hardEH2's Avatar
Default Re: *+*DO YOU KNOW A RIMS SHOP THAT DOES THIS WORK*+* (TunerN00b)
i think that process would be quite expensive. Its called electroplating where the metal gets current passed through it.. it causes it to be very strong. The reason why rays did this to the rim was of course for protection from the elements, curbs, corrosion etc. The look is an added plus. The reason why I say it may be expensive is because titanium electroplating is recent development.
Old Jan 18, 2008 | 02:55 PM
r.wright's Avatar
Default Re: *+*DO YOU KNOW A RIMS SHOP THAT DOES THIS WORK*+* (hardEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hardEH2 &raquo;</TD></TR><TR><TD CLASS="quote">i think that process would be quite expensive. </TD></TR></TABLE> he is right. you might as well sell your set and buy the wheels in that coat already. you can't nickel and dime a quality process like this.. i would estimate this process to be at least 1k because a 'quality' chrome plate job..i'm talking quality would be at least in the $700 and up range.
Old Jan 18, 2008 | 03:05 PM
JiZzEr's Avatar
if not that process then something similar
Old Jan 18, 2008 | 10:31 PM
McLaren Int'l's Avatar
Default Re: (JiZzEr)
I am not sure if this would work but maybe try a full polish on the wheel but then have a colored type of clearcoat on top or a colored tinted anodize on top? Not sure but might work. Contact rainbow polishing and I think there is another shop called bright wheels(?) near the southbay.
Old Jan 18, 2008 | 10:41 PM
toyomatt84's Avatar
Sanji
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JiZzEr &raquo;</TD></TR><TR><TD CLASS="quote">if not that process then something similar</TD></TR></TABLE>
Aurora Coating.
JiZzEr
Jan 18, 2008 03:16 PM
JiZzEr
Jan 18, 2008 03:05 PM
E46Kid
Northern California (Sales)
Dec 26, 2007 04:02 PM
jman245
Aug 21, 2007 07:27 PM
SD1222
Mar 8, 2005 04:05 PM
