fully built h22a TURBO project
here a start for me, got this done a while back and it still sitting in my garage waiting for the summer so i can put it all together. nothing is assemble yet.. also any advice on the balancer? can i just stuck the balancer shaft into the block and leave it there instead of getting a balancer eliminator kit?
right now im running a G22(f22b2 block with h22 head) Turbo setup in my 5th gen..about to switch over to the fully built this summer
the block is 87mm sleeved, 87mm CP 9:1 piston, eagle rods, and micropolish crank.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietdragontekx »</TD></TR><TR><TD CLASS="quote">here a start for me, got this done a while back and it still sitting in my garage waiting for the summer so i can put it all together. nothing is assemble yet.. also any advice on the balancer? can i just stuck the balancer shaft into the block and leave it there instead of getting a balancer eliminator kit?
nice! if you don't want to get the balance shaft eliminator kit you can just reinstall the shafts and just leave the belt off. i would recommend getting the eliminator kit though. the balance shafts are quite heavy and you already have it all apart... might as well do it..
Good luck! keep us posted when its done and dyno'd! what engine management are you going with? also what turbo setup? if you don't mind me asking.
</TD></TR></TABLE>nice! if you don't want to get the balance shaft eliminator kit you can just reinstall the shafts and just leave the belt off. i would recommend getting the eliminator kit though. the balance shafts are quite heavy and you already have it all apart... might as well do it..
im running honda s300 with a p28 ecu right now on my G22 setup with a turbonetic turbo kit with an upgraded t60 turbo. probably will be running the same thing on the built motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietdragontekx »</TD></TR><TR><TD CLASS="quote">im running honda s300 with a p28 ecu right now on my G22 setup with a turbonetic turbo kit with an upgraded t60 turbo. probably will be running the same thing on the built motor. </TD></TR></TABLE>
cool.. should run great.. good luck with the build
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lubo_25 »</TD></TR><TR><TD CLASS="quote">sleeve install looks flawless
Yes it does. What sleeves are you using?
What turbo manifold?
There appears to be anybody who makes a turbo manifold that keeps a/c without going log. Curious if you choose to drive without a/c.
yeh sleeved was install by a local machine shop that i know of. they did a really good job.
as for the G22, it been running good. boosted 11.5 psi on it daily and it still fine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietdragontekx »</TD></TR><TR><TD CLASS="quote">im looking for around 400-500 whp.. that enough for me</TD></TR></TABLE>
Damn that's a lot! I hope your tranny doesn't break! Get a good clutch/drive shafts!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietdragontekx »</TD></TR><TR><TD CLASS="quote">i got a built h23 tranny with quaife lsd, going to get some racing axle </TD></TR></TABLE>
Built how? Just curious
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietdragontekx »</TD></TR><TR><TD CLASS="quote">stronger gears was install and coated. install quaife lsd. all was done at a shop, i forgot the name. </TD></TR></TABLE>
Ahh....cryo-treated? I would love to get a taller 5th gear for mine for cruising.
Why do you feel the need to get racing axles?
