which tranny is better f22 manuel or h22 manuel
im going f20b dual cam european.. my question is what is the difference in both of the trannys.. its going to be put in a 88-91 civic hatch daliy driver.. they both cost about the same.. so please help....
do a hibryd.
h22 1-3rd or 1-4th its up to you, and f22 5th for highway crusing so you don't rev out
the h22 is good for acceleration, but sucks for highway, you'll use more gas than f22
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by down4whatever420 »</TD></TR><TR><TD CLASS="quote">what do you mean hybrid.. like different gearing</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sony224422 »</TD></TR><TR><TD CLASS="quote">do a hybrid.
the h22 is good for acceleration, but sucks for highway, you'll use more gas than f22</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sony224422 »</TD></TR><TR><TD CLASS="quote">do a hibryd.
Found this elsewhere...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">yes, it can be done. I have pulled apart a usdm h22a transmission and have been able to replace the counter and main shaft 5th gears HOWEVER, the 5th gear on the main shaft side is a little bit taller than the original and the only way to get it to fit would be to have it machined down, which could impact its structural integrity. Because of this risk, I chose not to attempt the swap but I'm almost positive that it can be done and work. It was just not a risk I could afford $$$$ to take.</TD></TR></TABLE>
Modified by 213374U at 8:53 PM 1/19/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4163175587 »</TD></TR><TR><TD CLASS="quote">h22 will always be better than f22. In other cases when its built and in all cases stock</TD></TR></TABLE>
One of the more idiotic responses I've read in a while. If the H22 tranny was "always" better, why didn't Honda save themselves the trouble and just mate that tranny to the F22 from the factory? Think before you post... :cough:jackass:cough:
hmm. i know people do it, i don't think thats true but i don't know. i was told it would work from 2 or 3 different honda techs with no problem. im pretty sure they are the same in size.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sony224422 »</TD></TR><TR><TD CLASS="quote">hmm. i know people do it, i don't think thats true but i don't know. i was told it would work from 2 or 3 different honda techs with no problem. im pretty sure they are the same in size.</TD></TR></TABLE>
Throw up some links man... if it's that easy, I'm down to be the guinea pig
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sony224422 »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=2172085</TD></TR></TABLE>
I thought you were going to post a link to some sort of how-to or at least someone who has done it successfully. That's just a less intuitive version of what I posted above. Considering the source, it's gonna take a little more research before I go diving into this one.
Well, I'm picking up my swap here in the next 2 weeks or so. I'll tear the trannies down, see what's up and if it looks promising, expect a write-up from me inside of a month
CD8coupeSiR
May 12, 2006 04:00 AM
DA_KengV
Apr 25, 2003 06:41 PM
sh me luck
