Gasket between Header and Head ?
I'm putting a Greddy Header onto my 99 LS and was wondering whether an OEM gasket would work or if I need a special one or some kind of an upgrade. Quick help please.
Is the stock one layered sheet metal or the crushable material. I always thought the (felpro?) crushable one would make the best seal vs the layered one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thewrai6th »</TD></TR><TR><TD CLASS="quote">Is the stock one layered sheet metal or the crushable material. I always thought the (felpro?) crushable one would make the best seal vs the layered one.</TD></TR></TABLE>
hmmm felpro should be metal as well....only time you see a "crush" type gasket is in the actual exhaust system piping i.e. a flange gasket
On my old D, the gasket from kragen was the crushable material, kind of like the flange gasket material, but thin. That one is a one-use gasket and has to be cleaned off the head and mani.
OEM FTW
OEM FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thewrai6th »</TD></TR><TR><TD CLASS="quote">On my old D, the gasket from kragen was the crushable material, kind of like the flange gasket material, but thin. That one is a one-use gasket and has to be cleaned off the head and mani.
OEM FTW</TD></TR></TABLE>
ahhhh i'm sure they make them, but all i've ever seen is the metal, even from felpro....interesting (probably really cheap too)
