bumper question
there are three screws inbetween the head lights, two srews under the corner lights( when you remove the corners, one on each side), two on each side of the bumper, and some under the bumper....hope that helps
there 2 screw on each side by the tire wall that connects to bumper and take off your both of your bumper light and there should be 2 size 12 mm bolts each side take those off and the bumper should come off
When I took my front bumper off the car it took a whole lot of yanking to get it off. I removed all the screws, and even the 3 screws between my headlights. After I got it all off I noticed that I cracked the top of my bumper because where the 3 screws were, the bumper was still stuck in there for some reason. So when I yanked, it broke the 3 holes where the screws went through and cracked the bumper. Is there a special way to take the bumper off other than yanking? Should I have pried up the metal piece that the bumper slid into under the screws?
Start by leaving all of the bolts that you have already pulled out of. Next pull out your front bumper lights and set them to the side. If you look behind them you can see two bolts (10mm I think). Be careful when pulling these by yourself because one side will fall if you do it one side at a time. Try to prop one side up, pull one bolt on that side. Then go to the other , pull both of those and see if you can't hold that side up with something and pull the other bolt out from the other side. The only thing is that this pulls the whole bumper off not just the cover. Still have not tryed to pull just the cover off yet . hope that this will help.
gsrpedro
Feb 28, 2007 08:23 PM
SupraRXZ
14
Nov 29, 2006 10:30 AM
