Fuel spraying out of fuel rail!
I got my DPFI to MPFI conversion done, and I was having trouble figuring out how the stock fuel line is supposed to work with the new fuel rail. I tried cranking it over and fuel sprayed all over from the fuel supply line and pulsation dampner area. All I have on the passenger side end of the fuel rail is the pipe that sticks out that has a hole in the top (not the side as with the DPFI one), the original DPFI foes hose, a washer, and the pulsation dampner. What am I missing here? I cant see a clear view of what parts I am supposed to have in the FSM.
Not spraying out of the rail near the injectors. Spraying out of the end of the rail where the fuel supply hose and pulsation dampner connect. Thank you for the help but I think maybe you skipped reading the post?
Your missing a washer. Don't tell me you reused the old washer. You know when you disassemble components on a fuel rail. The washers need to be replaced. The old ones were crushed when torque and they are no good after that.
mine did that thay need to heat up a bit but its a bad idea if u got fuel in the lines lol best way is to drain the fuel then use a head guy to warm up the seals thay will get bigger i had the problem i let it sit over night and thay closed up it leaked a bit just move the injecter a bit left and right and try agan let it sit over night agan if it stil leaks get them replaced lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mario_pic »</TD></TR><TR><TD CLASS="quote">mine did that thay need to heat up a bit but its a bad idea if u got fuel in the lines lol best way is to drain the fuel then use a head guy to warm up the seals thay will get bigger i had the problem i let it sit over night and thay closed up it leaked a bit just move the injecter a bit left and right and try agan let it sit over night agan if it stil leaks get them replaced lol</TD></TR></TABLE>
Was this english? And please dont type "LOL" anymore, you clearly dont know what it means guessing by the way you used it.
yeah i missed that. my haynes manual doesn't show an exploded view of the fuel rail so I didn't know I was missing anything
going to the stealership today to get parts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DailyDriverCivic »</TD></TR><TR><TD CLASS="quote">
Was this english? And please dont type "LOL" anymore, you clearly dont know what it means guessing by the way you used it.</TD></TR></TABLE>
LoL!! Go ez on them...their learning...probably in pre-K or something close to that..LOL...sry bro..couldnt help it.
