What motor oil for initial startup?
Old Jan 17, 2008 | 04:17 PM
eg_h22's Avatar
From: Beautiful beaches, skies, and ladies. No worries(.) @ the OBX, NC
Default What motor oil for initial startup?
Have a h22 swap and would like some advice on what motor oil I should use initially for the first startup and then a few hundred miles down the road?
Thanks
Old Jan 17, 2008 | 05:40 PM
festivagt's Avatar
Default Re: What motor oil for initial startup? (eg_h22)
Well, if it is used (out of a crate from japan - you did say swap) run some conventional for 500 miles then use whatever you want. If it is a FRESH engine- just built - Follow the shops reccommendations(some places give you a warranty - don't void it) But they will usually tell you not to use anything but conventional oil for the first few oil changes(500, 1500) then use what you want.
HENRY
Old Jan 18, 2008 | 10:53 AM
quicksilver1689's Avatar
i ♥ snails
if the motor is brand new i use a non detergent cheap oil since im going to flush it out only after a few miles.
Old Jan 18, 2008 | 11:23 AM
LastGenEK's Avatar
Default Re: (quicksilver1689)
anything but synthetic, i heard the piston rings dont break in as well
Old Jan 18, 2008 | 01:25 PM
eg_h22's Avatar
Default Re: (LastGenEK)
its a used motor from japan... but I just built the head
Old Jan 19, 2008 | 07:19 AM
blkb18's Avatar
Default Re: (eg_h22)
The head doesent need a break in, its the cylinder wall to piston ring contact surface that "breaks in". But if you didnt rering/hone it then it should be broken in. Try some non syn 5w30 to be on the safe side.
Old Jan 19, 2008 | 02:16 PM
HeikDiesel's Avatar
Default Re: (blkb18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkb18 &raquo;</TD></TR><TR><TD CLASS="quote">The head doesent need a break in, its the cylinder wall to piston ring contact surface that "breaks in". </TD></TR></TABLE>
Old Jan 20, 2008 | 02:13 PM
Mikey3000's Avatar
Default Re: (HeikDiesel)
just use your typical synthetic oil. non synthetic is only for new rings.
Highpower
11
Oct 16, 2019 03:53 AM
TiGASNANGULO
Sep 16, 2009 12:45 PM
aeolus
62
Mar 13, 2009 08:24 PM
-KangaRod-
37
Feb 22, 2004 05:50 AM
boostedcoupe
Nov 1, 2002 03:11 AM
