heater core
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wicked_b16eg »</TD></TR><TR><TD CLASS="quote">if your leaking coolant on the passenger side then yea your heater core is bad</TD></TR></TABLE>
but would it cause my ride to overheat, because when i drive my car overheats but when my car is parked for about 2mins, it cools back down without the fan because my relay or something is broken; so the fan is not running at all!!
Is there any Puddles under the Car? If there are Look Directly Above Them.
Is the Coolant Full?
When you Fill it Back Up does it Pour Right Out anywhere?
when its running.
Is the Rad Hot Everywhere on it?
Is your upper rad hose hot?
Is the Comming on?
Try Opening the Bleeder Screw to Relase Trapped air?
A non spinning water pump?
You may Even Have a Head Gasket Problem?
when its running.
Is the Comming on?
well as i was driving on the small street i had no problem with it over heating but when i hit the freeway going about 75 to 80 mph, my starts to overheat, im thinking that something might be plugged and it cant be my radiator because the radiator is my brothers which i switched with him! so what could it be?? any suggestions!!
