connect ipod to head unit via aux cable.
Old Jan 17, 2008 | 12:40 PM
oddmut's Avatar
Default connect ipod to head unit via aux cable.
Here's my head unit:
Here's the back of it:
I have an auxilary option for the stereo. I don't know how to hook it up to my Ipod. I was planning on buying an aux cable to go from my ipod to the head unit. it works like that in my gf's scion. Would that work the same with mine? if so where the heck do i plug it into?
Old Jan 17, 2008 | 03:54 PM
B18C_EJ8's Avatar
Stop prying dash panels with screwdrivers...
Anyways, you would buy an aux-input adapter for a Panasonic deck. Unless your GF's Scion has a Panasonic deck in it, the same cable won't work.
The iPod adapters at Crutchfield say that they're for 2006 and newer Panasonic decks, and the sticker on the bottom of your deck says 2004. So you're out of luck with that kind of iPod adapter.
But you could use a regular old aux-in adapter, although I couldn't find one that said it worked with decks older than 2006. Also, I'm unsure of whether or not the adapter would plug into the round CD changer port on the deck or if one of the sets of RCA's is an aux input. Since you didn't bother to tell us the model of the number of the deck, that's all I can tell you.
Old Jan 17, 2008 | 07:19 PM
oddmut's Avatar
Default Re: (B18C_EJ8)
What do I use to pop the dash open? my flat head doesn't damage anything. I haven't gotten any damage to it yet. It just reshapes right after. Like memory foam or some ****.
I don't know much about my stereo. I think this is my model #CQ-C5310U
can u send me a link to an aux-input adapter?
Old Jan 18, 2008 | 06:19 AM
B18C_EJ8's Avatar
I was going to tell you to do your own research, but since I'm home with a sick kid who's asleep right now, I've really got nothing better to do.
If you read your manual http://service.us.panasonic.co...U.PDF), or even looked at the little white sleeves on the RCA's on the back of the deck, you'd see that one of the sets of RCA's is an Aux-In.
In that case, you'll need a simple headphone-to-RCA adapter cable like this one:
http://edifier.ca/eshop/images/L221MM-2.jpg
One end plugs into the headphone jack on your iPod, and the other connects to the AUX-in RCA's on the back of the deck.
You will then press the "source" button until "AUX" shows on the screen.
You won't be able to control the iPod through the deck like a true iPod interface, but it's better than nothing.
Old Jan 18, 2008 | 06:27 AM
fcm's Avatar
fcm
Old Fart
Default Re: (oddmut)
A little better... http://www.installer.com/aux/ 3rd one down. 94
Old Jan 18, 2008 | 07:10 AM
B18C_EJ8's Avatar
Or that one..
Old Jan 18, 2008 | 11:33 AM
thehatchninja's Avatar
i've been looking into how to do an input on the factory radio. I found an AUX RCA input on that site for like $14. Awesome, unfortunately I have to lose my factory CD changer.
Old Jan 18, 2008 | 12:50 PM
oddmut's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">I was going to tell you to do your own research, but since I'm home with a sick kid who's asleep right now, I've really got nothing better to do.
thank you thank you. never did look at the manual too thoroughly. i think i got confused that's why. lol.
btw you said not to use the screw driver. then what to use to remove the dash?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">A little better... http://www.installer.com/aux/ 3rd one down. 94</TD></TR></TABLE>
fcm thanks. i think i'll go with that one instead. looks nicer. hehe.
Old Jan 18, 2008 | 01:57 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oddmut &raquo;</TD></TR><TR><TD CLASS="quote">
You'll rarely catch a professional installer using a screwdriver to pry a panel out/off.
I personally use a nylon panel tool like the one on the far right: http://shoptoolsshoptools.com/shopexd.asp?id=24298
Or, in that particular car, you should be able to reach up in the cavity below the radio & push the whole assembly with your hand. No tools required.
Old Jan 19, 2008 | 12:12 PM
oddmut's Avatar
ic. why would a flat head not be similar to the tool you just referenced. I've had no damages whatsoever. never tried sticking my hand behind it. maybe i'll try that next time.
Old Jan 20, 2008 | 12:29 PM
SurfDan5's Avatar
check out the cleansweeps at jlaudio.com
Old Jan 20, 2008 | 01:27 PM
B18C_EJ8's Avatar
Default Re: (SurfDan5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SurfDan5 &raquo;</TD></TR><TR><TD CLASS="quote">check out the cleansweeps at jlaudio.com </TD></TR></TABLE>
Wait... What??
Old Jan 20, 2008 | 05:16 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Wait... What??</TD></TR></TABLE> I would ask, Why?? 94
Old Jan 20, 2008 | 05:26 PM
B18C_EJ8's Avatar
I know that you can plug an iPod into the CleanSweeps, but jeez... TOTAL overkill for this guy's setup.
Old Jan 22, 2008 | 08:57 AM
oddmut's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">I know that you can plug an iPod into the CleanSweeps, but jeez... TOTAL overkill for this guy's setup.</TD></TR></TABLE>
i would also have to say extremely over kill. at first i was like huh lost.
the cord would be sufficient. Thanks guys!
Old Jan 24, 2008 | 12:29 PM
Hyard24's Avatar
Why not buy an IPod ready CD deck and run the cable that comes with it through and out into the center console? That's what I did. My CD deck controls my ipod so I never have to mess with it, it just sits inside my console.
Old Jan 24, 2008 | 12:36 PM
B18C_EJ8's Avatar
Default Re: (Hyard24)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hyard24 &raquo;</TD></TR><TR><TD CLASS="quote">Why not buy an IPod ready CD deck and run the cable that comes with it through and out into the center console? That's what I did. My CD deck controls my ipod so I never have to mess with it, it just sits inside my console.</TD></TR></TABLE>
First, what decks come with the iPod interface cable? I don't know of any.
Second, why buy a $150+ deck when a $10 cable will do the job?
Old Jan 24, 2008 | 04:45 PM
VTEC_PRODUCTION's Avatar
i see there is a spot for an aux. cable...just buy an aux cable match the colors and route that cable however you want without pinching it put that head unit on AUX and play away using your ipod. simple.
Old Jan 24, 2008 | 07:09 PM
B18C_EJ8's Avatar
Default Re: (VTEC_PRODUCTION)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_PRODUCTION &raquo;</TD></TR><TR><TD CLASS="quote">
i see there is a spot for an aux. cable...just buy an aux cable match the colors and route that cable however you want without pinching it put that head unit on AUX and play away using your ipod. simple.</TD></TR></TABLE>
Hey thanks for answering the question that's been answered already.
And what's with quoting me?
Old Jan 25, 2008 | 04:26 AM
And what's with quoting me? </TD></TR></TABLE>
sorry if i answered already...and there are a few decks with ipod interface built in...like the alpine with the small screen in it.
Old Jan 25, 2008 | 04:44 AM
B18C_EJ8's Avatar
and there are a few decks with ipod interface built in...like the alpine with the small screen in it. </TD></TR></TABLE>
Again, already discussed.
Old Jan 25, 2008 | 04:59 AM
my bad...can i have help on my thread though?
Old Jan 25, 2008 | 07:31 AM
audioroach's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oddmut &raquo;</TD></TR><TR><TD CLASS="quote">ic. why would a flat head not be similar to the tool you just referenced. I've had no damages whatsoever. never tried sticking my hand behind it. maybe i'll try that next time.</TD></TR></TABLE>
*sigh*...newbs
Okay You have been lucky. You can and WILL damage/destroy a dash panel with a metal tool...its only a matter of time. If you are going to work on your car use the right tools!! The price of the Nylon tools range from under $10 for a set (harbor frieght tools) to $40 for a pro set. The nylon tool allows for safe prying WITHOUT damaging or scratching the area your working on.
Old Jan 25, 2008 | 08:21 PM
8520's Avatar
Default Re: (audioroach)
You have no idea how many 01-06 civics I see with pry marks on their dashes from installers who didn't know what they were doing.
Certainly doesn't help that the clips holding those particular bezels in are angry as all hell
Mark Bird
Audio / Security / Video
Jun 28, 2017 02:20 AM
johanG
Jan 1, 2009 09:48 AM
teggsr925
Dec 30, 2006 03:12 PM
SkRiBLaH
Oct 11, 2005 09:35 AM
humtake
Sep 29, 2003 12:20 PM
