P28 in 99 civic
Old Jan 17, 2008 | 11:33 AM
boost and bass's Avatar
Default P28 in 99 civic
I put my P28 ecu with the conversion harness in my 99 dx and the idle is a bit jumpy and when ever i release the gas the car kinda jerks, im pretty sure this is because of the IACv if not what u guys think, and if it is what can be done to fix this. Also i might be crazy but it seems the car is a bit slower is this possible?
Old Jan 17, 2008 | 11:37 AM
yoffer's Avatar
Banned
what motor are you running the p28 on?
Old Jan 17, 2008 | 11:40 AM
its a d16y7 for now im building up a y8 project but i wanted to install the ecu so i can wire my gauges to the conversion harness so i dont have to cut up the factory harness
Old Jan 17, 2008 | 12:02 PM
yoffer's Avatar
Banned
So why would you run a sohc vtec ecu on a non-vtec motor? Put the old ecu back in and run it until your done with the y8. Then you can run the p28.
Old Jan 17, 2008 | 06:16 PM
its wat i did i just wanted to see how it would run and as i said id like to hook up the gauges i have through the conversion harness
Old Jan 17, 2008 | 06:34 PM
boosted92hatch's Avatar
Default Re: (boost and bass)
try disconnecting the ckp sensor plug near the end of the timing cover, its the wire that goes under the timing cover. it has 3 wires coming out of the plug. mine did the same thing
Old Jan 18, 2008 | 09:34 AM
will do!
ej8ster96
Jun 23, 2009 07:57 AM
profesional-hobo
Texas -OK -LA (Sales)
Apr 3, 2009 02:23 PM
lumpylude
Sep 12, 2007 03:21 PM
specv5150
Jun 19, 2005 10:07 AM
