Anyone running on stock ITR suspension on EG?
Old Jul 1, 2002 | 02:03 AM
Mugen_R's Avatar
New User
Default Anyone running on stock ITR suspension on EG?
Hi all,
Just like to know how they go? good? perform well?
Isit a complete bolt on? or do you need the rear lower arm?
Anyone else running the ITR shocks with different springs (lowered)? what type of springs?
Thanks
Old Jul 1, 2002 | 03:12 AM
VWkila's Avatar
Default Re: Anyone running on stock ITR suspension on EG? (Mugen_R)
It's a complete bolt on. On the rear, ITR Lower Control Arms are different than the rest of the Integra lineup. Regular Integra shocks will not fit the ITR LCAs.
I have the Koni Yellows with H&R Sport springs on my HB.
Old Jul 1, 2002 | 05:23 AM
Mugen_R's Avatar
New User
Default Re: Anyone running on stock ITR suspension on EG? (VWkila)
so does that mean...
in order for me to use the stock ITR sussy, i'll need to use the ITR's LCAs or it's a bolt on without it?
Old Jul 1, 2002 | 07:28 AM
CivicNewbie's Avatar
You will need the ITR LCA's if you want to use the ITR rear shocks on your EG
Old Jul 1, 2002 | 09:41 AM
hatchdrvr's Avatar
Front LCAs-->GSR, Type R=same Rear LCAs-->Type R=different
you can use GSR front lower LCAs to save $$ and just get the Type R rear LCAs
Old Jul 1, 2002 | 04:32 PM
VWkila's Avatar
Default Re: Anyone running on stock ITR suspension on EG? (ForceFedEG)
All Integra Front Lower Control Arms are the same. So, just get the ITR rear LCAs.
Old Jul 1, 2002 | 05:59 PM
shawnhayes's Avatar
Well, that comes with a caveat. Some people CAN make them fit by spreading the fork of the shock. I understand that you can't do it with all shocks. Understandably, this isn't really recommended, but it will work.
Shawn
Old Jul 1, 2002 | 11:54 PM
Mugen_R's Avatar
New User
Default Re: Anyone running on stock ITR suspension on EG? (shawnhayes)
Thanks guys. How much do you normally pick up a set of stock ITR shocks for in the states? So i can have a rough idea how much i should be paying for them. They are very rare around here.
Old Jul 2, 2002 | 01:40 AM
ITRinEJ1's Avatar
spring/shock combo usually go for around 250 USD
Old Jul 2, 2002 | 03:43 AM
VWkila's Avatar
Default Re: Anyone running on stock ITR suspension on EG? (ITRinEJ1)
As far as rear shocks are concerned, You CAN NOT spread the non-ITR shocks to fit ITR shocks. Non-ITR shocks are "fork" shaped and ITRs are "cyclinder" shaped, or I've heard them described as "truck" like.
For my Koni Yellow, H&R Sport springs, I paid $700 through tirerack.com
[Modified by VWkila, 12:48 PM 7/2/2002]
8o8da9speed
Nov 18, 2004 05:20 AM
Shark Tank
Feb 16, 2003 05:06 PM
RoAnSa
12
Nov 24, 2002 07:54 AM
NAB
Apr 7, 2002 11:34 PM
Beyond Imagination
Mar 15, 2002 04:26 AM
