cams help
Old Jan 16, 2008 | 07:16 PM
w0nd3r's Avatar
Default cams help
which are better to put in a b16 itr cams or ctr cams
Old Jan 16, 2008 | 07:18 PM
wicked_b16eg's Avatar
Default Re: cams help (w0nd3r)
Itr or ctr.. on a stock B16 they will do the same thing. You only need to use the Intake cam, The exhaust are all about the same
Old Jan 16, 2008 | 07:20 PM
z6hatchboy's Avatar
Default Re: cams help (wicked_b16eg)
True, the ctr intake cam has a fraction bigger profile to it. Exhaust's are basically the same.
Old Jan 16, 2008 | 07:39 PM
ekBlackHatch's Avatar
Default Re: cams help (z6hatchboy)
what he said most b series exhaust cams have same profile but the ctr intake cam is the most aggresive oem cam you can get. have you thought about after market cams a mild one if your on a budget you can pick up some bloxbs for cheap, if not look into rocket m22x or bc3s or bc4s
andyboy
Jul 21, 2004 07:29 PM
andyboy
Jul 21, 2004 06:37 PM
Quiks66
Oct 31, 2003 05:40 PM
AllMoToRB18c
Oct 26, 2003 02:33 PM
SoCaLNaTIvE
Sep 12, 2002 05:49 PM
