how to make 4wd
Old Jan 16, 2008 | 07:02 PM
90civicgsr's Avatar
Default how to make 4wd
i have a 92 civic hatch and i seen it done a couple times but was wondering how to make mine 4wd. if you know please let me know what to do. thanks
Old Jan 16, 2008 | 09:27 PM
doood's Avatar
been there done that
Default Re: how to make 4wd (90civicgsr)
if you have to ask, you cant, and wont.
Old Jan 16, 2008 | 11:15 PM
HiProfile's Avatar
Default Re: how to make 4wd (doood)
Front half of car: B-series motor & CR-V trans or D-series motor & Wagovan RT-4WD trans
Mid/rear: Wagovan driveshaft & torque splitter or custom driveshaft, Wagovan or CR-V rear differential, Wagovan or custom trailing arms, enlarged exhaust/driveshaft tunnel, custom fuel cell (or cut up a Wagovan tank).
In a perfect world, you would be able to stuff the car with a turbo B-series, mate to a CR-V trans with a different final drive, then connect the rear Wagovan diff to the 'transfer case' with a custom narrow driveshaft. W/o the splitter, the rear diff may not last. *Wagovan = Civic Wagon/5-door RT-4WD
If you want weld, its not worth doing it. Lots of custom mounts, cutting/rewelding, jigs, etc.
Old Jan 17, 2008 | 11:00 AM
92civicx's Avatar
Default Re: how to make 4wd (HiProfile)
https://honda-tech.com/zerothread?id=1708933 here's a build
Nate8o8_EP3
Aug 11, 2018 02:23 PM
grey_box008
Honda CR-V & Element
49
May 16, 2013 09:27 AM
96civich22
Mar 28, 2007 05:56 PM
AR Fab
Apr 21, 2006 10:33 AM
Benbuilt4u
Sep 6, 2003 08:19 PM
