need help on 97 civic hatch spring install
Old Jan 16, 2008 | 06:12 PM
degi326's Avatar
Default need help on 97 civic hatch spring install
does any one have writeup of that? i am stuck on rear shock removal do i have to take off the plastice panel first ? i have a 97 hatch civic
Old Jan 16, 2008 | 06:16 PM
z6hatchboy's Avatar
Default Re: need help on 97 civic hatch spring install (degi326)
Jack the car up, support it, undo the bolt behind the cup on the bottom of the shock and let the LCA and componets fall, then take off that plastic piece in the hatch to reveal the shock bolt/nuts, undo them and it should drop right out.
Old Jan 16, 2008 | 06:22 PM
DCSportEJ1Civic's Avatar
Default Re: need help on 97 civic hatch spring install (z6hatchboy)
heads up on the lower contol arm bolt. theyre know to seize inside the bushing an break.
Old Jan 16, 2008 | 06:27 PM
z6hatchboy's Avatar
Default Re: need help on 97 civic hatch spring install (DCSportEJ1Civic)
^^^ deff true, but thats why you take the bolt in the back of the shock cup out so you can just push the drum/caliper/LCA stuff down and pull the shock out of the cup and out of the car
Old Jan 16, 2008 | 06:48 PM
aarethas's Avatar
Jack the back of the car up and put on jackstands.
take the wheels off.
Use a floor jack to support the trailing arm that you are undoing.
remove the plastic panel that hides the upper bolts.
Undo the two smaller bolts at the top.
at the bottom of the assembly, unto the back bolt that connects to the shock assembly.
Lower the jack slowly so that the arm hangs down.
Remove the shock assembly.
Install in reverse!
Old Jan 16, 2008 | 06:49 PM
DAMN, i never thought of doing that. good stuff.
Fliptard
Aug 30, 2012 12:02 PM
civlxbro
Suspension & Brakes
Oct 4, 2009 07:51 AM
tdubbebawllin
Sep 10, 2008 07:24 PM
Wonk Unit
Suspension & Brakes
13
Jul 25, 2006 07:33 AM
blufke
10
Mar 17, 2003 09:27 PM
