brake question
if i had no pressure on my brake pedal and i bled the brakes and there was still no pressure and i found out that i had a clogged brake hose and i replace it will i definently need to bleed the brakes again
From: Staring down the barrell of my 12 ga. Texas, USA
unless you pre bled the hoses, yes you need to bleed to brakes again.
basically there is no fluid in them when you installed them
also, i is a safe bet to do it
the fluid is pretty cheap
dnt94civic
Jun 7, 2002 05:04 AM
